I need help troubleshooting brake problem
I'm the fourth owner of a six year old E-M Cobra with 1987 Corvette suspension and Tilton brakes and clutch. A few weeks ago I replaced the clutch master cylinder after I noticed it leaking. There was significant wear in the bore of the master cylinder. Lately, I noticed that while sitting still with steady pressure on the brake pedal (cool brakes), after about 15-20 seconds, the pedal drops abruptly about a half inch. If I maintain steady pressure, it will continue to drop in little steps about every 5 - 8 seconds. Resevoirs on both brake master cylinders (its a dual system with adjustable brake bias) seem full and there are no apparent leaks. I suspect this phenomenon is caused by wear in one or both brake master cylinders. What do you guys think?
If there is no external leaks than it's internal. The brake fluid is bypassing the cups(seals) on the piston. A rebuild/replacement is in order. Bill
| All times are GMT -7. The time now is 09:41 AM. |
