brake line size? is bigger better, or is that just what she say's?
anyone out there use the larger brake lines other than the standard 3/16's steel?
if so, can you tell a difference in stopping power? or any difference at all. i was considering rerunning and cleaning up my lines and thought i had read something in the past about this but could not find the article i thought i saw. seems like i read the parts were hard to find but was worth the effort. any comments from the experienced? thanks clay |
There's no good reason to use larger than a 3/16" line for the brakes. Fluid volume is very small.
In fact, the pressure rating rating decreases as the line gets larger. The clutch however, should use a larger size so that on release, there's less restriction to flow. |
thanks bob
you just saved me a huge headache. my clutch currently has 3/16s also, i will go ahead and change that one.. thanks clay |
| All times are GMT -7. The time now is 01:02 PM. |
