SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
  #21 (permalink)
Old 06-07-2004, 08:29 AM
goaztecs's Avatar
Cobra Make, Engine: LA Exotics (B&B) Cobra, 408W, Roush Heads, Demon Carb, Comp Cam, Tremec Z-Spec T5, 9" Auburn Rear
OK,
We're using the term "positraction" as a differential type, but I always thought that that positraction was just the GM name for their limited-slip diff, just like Traction-Lok is a Ford term. Have I been goofy all these years? Isn't positraction a brand name, versus a technical description?
Check out the Bay Area Cobra Club Website at http://www.bayareacobraclub.com
  #22 (permalink)
Old 06-07-2004, 08:40 AM
Yes, you're right....Posi & Trac-Lok are both trade names....However, both use mechanical ways of locking up....i.e. clutch packs & springs....
The LSD units could possibly use clutch packs also, but there are other types of LSD's that use a fluid to lockup....like a torque converter....or the central LSD on say an AWD Lamborghini or Porsche.
It's hard to be "politically correct" when describing this stuff. There's too many trade names and too many names of definition.
I guess all differentials that allow traction to be transferred to one wheel or both are all types of limited slip units....However, not all limited slip units involve mechanical friction...i.e. clutches, shims, springs, etc. as stated above. Some rely on viscosity...
I guess they all perform the same function....but in my mind, when I think of posi-traction (like a GM or a Trac-Lok) I think of clutches inside....when I think of a LSD unit, my mind thinks in broader terms.....
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
  #23 (permalink)
Old 06-07-2004, 09:31 AM
goaztecs's Avatar
blykins,
Thanks for the clarification.
/Chris
  #24 (permalink)
Old 06-10-2004, 07:26 AM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
Take a look at Powertrax limited slip. They are a backyard install.
www.powertrax.com
  #25 (permalink)
Old 06-10-2004, 07:29 AM
I've seen those....it doesn't look like too bad of a job. Basically you're just removing the spider gears and installing this puppy....which is more or less a detroit locker.....
Display Modes
HTML code is On
