-   Shop Talk (http://www.clubcobra.com/forums/shop-talk/)
-   -   Torque settings for re-installing a clutch (http://www.clubcobra.com/forums/shop-talk/21253-torque-settings-re-installing-clutch.html)
Wisconsin_Snake 10-25-2002 10:30 PM
Can someone please tell me what to lbs to torque the flywheel bolts to?
Also what to torque the pressure plate to???
I am using a 95 flywheel, which using metric threaded bolts...
I got some bolts from a hardware store, I sheared one one head... Someone told me to torque the pressure plate to 50 lbs... Now I am thinking that statement might be wrong...
Thanks...
Cobra20646 10-27-2002 05:09 AM
According to my small block ford book....
Flywheel - 75 to 85 pounds
Clutch Plate - 12 to 20 pounds
and get the right bolts. Either after market flywheel/clutch bolts or from a Ford dealer. Don't mess with the hardware store stuff here. Plus the Ford bolts come with a thread locker allready applied.
- Jim -
ERA 626 10-27-2002 09:33 AM
I just went through this.
I am not sure about the pressure plate but the flywheel:
60lbs if using arp lube
75-80lbs if using oil
hope this helps
Mike
PS USE ARP BOLTS!!!!!
Mr.Fixit 10-29-2002 08:19 AM
85 on the flywheel, 22 on the PP get new bolts too, don't reuse those old stretchy ones.
