oil leak
I still have an oil leak at the base of distributor. Engine is a 351W. I have already put a new o-ring on, and put a gasket on base of distributor, sitll leaks. Distributor is a new oem unit. Dont know what else to try, Does anyone have any suggestions, I would greatly appreciate any help.
I 'll bet your oil leak is coming from the front intake-manifold end gasket. Where the gasket makes the turn around behind the distributor is notorious for pinching out and leaking. A leak here will run down behind the distributor, thus giving the false impression oil is coming from the distributor base.
I resort to using "gorilla snot", officially known as 3M Weatherstrip Adhesive, to glue the gasket to the block and keep it from pinching out as I torque down the manifold. So, take a good look at this area before you go any further. Good luck |
| All times are GMT -7. The time now is 04:39 AM. |
