-   Shop Talk (http://www.clubcobra.com/forums/shop-talk/)
-   -   Fuel Filler Hose - Where to buy?? (http://www.clubcobra.com/forums/shop-talk/22126-fuel-filler-hose-where-buy.html)
PSB 12-06-2002 07:04 AM
I need some 2" diameter fuel filler hose to conect the tank to the LeMans gascap. All the local auto parts stores I've checked so far just give me a dumb look then tell me that's a dealer part. Any suggestions? :confused:
Thanks,
Pete
kountzecobra 12-06-2002 07:16 AM
Most parts stores around here carry this type of hose. Maybe you will have to try a truck parts supplier or an industrial hose and fitting supplier. Surely anyone that carries Gates or another brand name hose can get it for you.
Back in Black 12-06-2002 08:19 AM
I am doing a 4 x 4 restoration project..
And I found the local heavy (commercial) truck supply has it, with the stainless steel re-inforcing coil in the hose...it's great stuff, about $1.00 per inch tho.. cut the hose with a hacksaw, and the then-exposed wire with bolt cutters.
Roscoe 12-06-2002 08:27 AM
A local marine store should have it, a store that sells speed parts, also mail order from
http://www.pegasusautoracing.com
http://www.racerpartswholesale.com
And many others.
Roscoe
Jack21 12-06-2002 04:57 PM
I ordered a foot of the stuff when I ordered the LeMans (actually, it's called the Aston Roller Latch) gascap from europaspares.com. It wasn't particularly expensive. Would think this would be a NAPA part.
hog 12-06-2002 05:43 PM
Shell Valley carries the hose you are looking for. It is part number 3041h112 and lists for $18.00 on their web site. www.shellvalley.com
Joe
PNJSNAK 12-08-2002 03:39 PM
Got mine from the local NAPA store. Just ask for 2" dia. fuel hose. It was $12.00 a foot. Pretty stiff hose, easier putting on when over 75 degrees ambient.
Howard Bosworth 12-11-2002 10:40 AM
Easiest way is call Shell Valley they can fix you up and you will have the part an a day or two.
Howard
