Shop Talk
http://www.clubcobra.com/forums/shop-talk/)
Where To Mount MSD
http://www.clubcobra.com/forums/shop-talk/39464-where-mount-msd.html)
| GeorgiaSnake |
03-12-2003 03:44 AM |
Where To Mount MSD
I'm laying out the harness and trying to find the best spot for the MSD Box. Comments and pictures would be great.
Randy
| Bill Wells |
03-12-2003 04:22 AM |
keep it away from the heat and where water wont run on it. mine is mounted on passenger side footwell area, up under dash where it is protected from engine bay heat, feet and water. they don't like to get hot as that is when 'msd' means 'mighty sorry device'. bill.
| Hotfingrs |
03-12-2003 04:26 AM |
mines mounted in the same spot.....
| 427 S/O |
03-12-2003 04:36 AM |
My MSD and coil is on the firewall, inside behind dash and insulated, ordered an extra 4' wire from MSD. I was a littled
concerned about the distance from the distributor but after many miles, no problem.....
| DougD |
03-12-2003 05:22 AM |
Ditto - mine's on the firewall, passenger side, inside the passenger compartment. I figured it would stay cooler and dry there, plus it's out of sight. If you get the 6AL, remember to mount the box so you can get at the rpm limiter chip, should you want to change it.
Doug
| jhaynie |
03-12-2003 06:11 AM |
Mines on the passenger side firewall behind the dash also. Must be the place to mount it.
John H
| Mark Roe |
03-12-2003 07:15 AM |
MSD Box
I've got mine on the passenger side footbox--inside the box on the top--out of sight--dry--and easy to get too.......
| chopper |
03-12-2003 07:21 AM |
I've got mine mounted on the back side of the dashboard, on the passenger side. I have two small pieces of angle-iron, attached to the dashsboard and dampened by rubber bushings, mounted vertically and bolted to the bottom dashboard brace. The MSD box is bolted to these uprights with the connections and limiter chip facing down.
| GeorgiaSnake |
03-12-2003 11:03 AM |
What a great site :cool:
Thanks guys - looks like it's in the upper part of the passenger footbox or backside of the dash.
Randy
| 427 S/O |
03-12-2003 02:25 PM |
I use the same S/S bolts for the MSD and the crankcase oil breather.
| Roscoe |
03-13-2003 11:43 AM |
Hey, here's a radical location for you - in the trunk! It's a 7AL-2, but that's where the guy who set up my EFI puts all of his units. No problems due to the long wire runs, either.
Viva la differance!
| Pete C |
03-17-2003 07:02 AM |
Roscoe,
The engine bay is not a good spot. I had my first MSD mounted there and I cooked it….too much heat. My engine seemed like it was running too fat and after screwing around with carbs I finally realized that there was an ignition problem. I now have mine mounted against the firewall in the passenger footbox. It is much cooler there.
Cheers, Pete
| Roscoe |
03-17-2003 11:42 AM |
Pete,
I hear ya. I've had this mounted there for almost 3 yrs and 13k. So far so good. Too late to move it now.
Roscoe
| Bill Wells |
03-17-2003 04:39 PM |
roscoe, you be a lucky dude. they don't like heat, that is when msd=might sorry device. bill
| All times are GMT -7. The time now is 09:20 AM. |
