SUPPORT OUR SPONSOR
December 2025
Old 05-11-2003, 07:21 PM
Cobra Make, Engine: Unique 427SC/331/5 forward
Question Not sure if this will help...
but I've had an oil leak in my XB3 crate motor too. Mine was at the #5 cylinder location, but was pooling oil on the lip on the bottom edge, topside of the valve cover. Turns out it's a crack in the cover, so fine you cannot see it - discovered when I yanked the cover and saw that the exh. rocker arm was rubbing on the cover. The inside of the cover (at the rocker location) was polished about 1/8" dia., and this had also caused the crack. Would weep oil only when running, and had no discernable source. Cure, until new covers arrive, was to shove the cover upward as much as the bolts will allow, and tighten down there - pretty much stopped the problem. Like I said, not sure if your troubles are similar - but worth a check.
Display Modes
HTML code is On
