Old 08-24-2003, 12:27 PM
Send a message via AIM to werthie
Default Expansion Tank Question--Please help
Greetings,
Does anyone know if the square tags on Cobra radiator expansion tanks are being reproduced? The late 289 Cobras had a metal expansion tank that is different from the FE (big block) expansion tanks typically found on Galaxies of the period. Was the Cobra expansion tank a one-off? Is anyone selling/reproducing it?
Many thanks,
Alan in So.Cal.
werthie@aol.com
Old 08-24-2003, 02:00 PM
ENTDOC's Avatar
I believe you are referring to the corvette Harrison aluminum tanks use in 289 cars.They are available through cobra restorers in atlanta and other vendors(finish line). chuck
Old 08-24-2003, 02:05 PM
Dear ENTDOC,
No, the expansion/surge tank I'm referring to is a brass tank that is similar but not identical to the tanks on 390 Ford motors. The latter tanks had the thermostat housing as part of the tank, whereas the 289 Cobras used the normal thermostat housing bolted to the motor.
Thanks for your reply,
Alan in So.Cal.
"If someone were to ask me for a short cut to sensuality, I would suggest he go shopping for a used 427 Shelby Cobra. But it is only fair to warn you that of the 300 guys who switched to them in 1966, only two went back to women."
--Mort Sahl
Old 08-24-2003, 04:08 PM
cobrajeff's Avatar
Default Street 289 Cobra expansion tank
I think THIS is the tank you are looking for.....
It has a smoother top, as opposed to the one used on 427/428 Cobras that had a higher top with ribs in it.
I believe the smooth top one came from earlier T'Birds & Lincolns (like around '61-'62 models), as opposed to the ribbed big-block one from mid-sixties model T'Bird & Lincolns.
regards,
cobrajeff
CobraJeff
ERA P 202
Old 08-24-2003, 06:19 PM
ENTDOC's Avatar
I have seen those tanks on ebay from time to time. chuck
