-   Shop Talk (http://www.clubcobra.com/forums/shop-talk/)
-   -   BDR Alternator problem (http://www.clubcobra.com/forums/shop-talk/45971-bdr-alternator-problem.html)
Blittleton 10-04-2003 05:54 PM
I have a Prostar Alternator. It has three wires, one goes to the battery, where do the other two go to? I'm assuming to a 12v source? The other to the Alt charging light? Any help would be appreciated.
Rick Parker 10-09-2003 08:26 PM
1 Attachment(s)
This may help, It was originally posted by Bob Putnam From ERA
Rick
Blittleton 10-10-2003 03:15 PM
Thanks for your help. It helped alot, thanks again
rbray 05-21-2004 02:43 PM
Hi Guys,
I'm going to use the setup labled Without ignition light in the above diagram. Does the dotted line labled from battery mean that I must run a wire to the battery? ( sorry for the stupid question). What size wire should I use and how do I attach it to the battery?
Thanks for the help, as you can tell I am not an electrical expert
Rick Parker 05-21-2004 05:06 PM
It should come from the fuse panel. Use 8 or 10 gage wire.
Rick
Cobra20646 05-23-2004 06:57 AM
Originally posted by rbray
Hi Guys,
Hey Rick, you're usually right on the money...
But the BATT lead from the alternator is most often connected to the same terminal on the starter solenoid with the positive cable from the battery.
- Jim -
