-   Shop Talk (http://www.clubcobra.com/forums/shop-talk/)
-   -   Front brakes (http://www.clubcobra.com/forums/shop-talk/47448-front-brakes.html)
cobrabuilderI 11-22-2003 05:02 AM
Front brakes
In looking at my front brakes, maybe you guys have a suggestion as to what to do-
The 12" approx. hose that attaches to calipers and then clips into tab that is on frame is the only two connections that hold it in place- My question is this- Is there a bracket of some sort or tie that you guys have used to hold the hose from hitting the support arms(can't think of the name of then right off hand)- it appears that the hose will rub on this arm after awile. There are holes on the arms that looks like a bracket of some sort would work- don't know if there is a factory part that normally holds the hose off this or just it just hangs- Also, painted calipers using standard spray paint- should I take this off and use high heat spray paint?
Cobras are the best-
