Shop Talk
http://www.clubcobra.com/forums/shop-talk/)
| Michael C Henry |
08-01-2004 05:15 PM |
Ford alternater charging system
I have the older small Ford 75 amp alt with an external four wire regulater.I need a diagram and some advice .I'm starting it after two years and a bunch of changes. I'm having my share of problems.and am having problems thinking ,I have a buzz from too much Iced tea( straight tea gives me buzz) and exhaust and excitement.Need a diagram please and any advice.I expected it to work.
| Bruce Edwards |
08-01-2004 06:50 PM |
Mike,
Do you have a old repair manual from the early 70's or late 60's? They show the system. If mot I would be happy to make a copy and send it to you by email
| Rick Parker |
08-01-2004 08:15 PM |
Do a search "wiring diagram" there are some diagrams posted that will be usable to you. An alternator with an external regulator is represented.
Rick
| Michael C Henry |
08-01-2004 09:33 PM |
I started checking at the plug at the regulater.I figured that I should have one wire switched by the ignition switch.remembered I had installed a diode on the "I" terminal wire, nothing at tha plug , current on the other side of the diode .Had seats out so I could fit under dash and follow the wires and all.Removed the diode and tested, it still worked must have been in backwards turned around and reconnected TA-DA!
| trularin |
08-02-2004 04:29 AM |
Print
If you are interested, I have a print of a 60s Tbird with a four wire alternator in my photo gallery.
This may be able to help you with your charging wiring.
:3DSMILE:
| sllib |
08-02-2004 06:19 AM |
ERA has wiring diagrams on their site.
Bill Stradtner
| Michael C Henry |
08-04-2004 02:15 PM |
When I started the car on Monday evening the Voltage meter went over to 16V for just a bit then trimmed down to the 13- 14 V area.Now on Wednesday the yellow top Optima battery has gone to below 10V.The charger seems to be warmer than usual.Did I kill it? I thought that they were indestructable?
| All times are GMT -7. The time now is 01:29 AM. |
