Shop Talk
http://www.clubcobra.com/forums/shop-talk/)
| Buzzmobile |
10-10-2004 05:48 PM |
Brake light weirdness
1 Attachment(s)
I am trying to sort out a brake light problem and any help is thanked. I have a SPF car and I think the switch everyone talks about is the culprit. But, I think someone has altered the original wiring and I am a bit baffled. I will try and describe what I have and hopefully attach a pic that can be seen???? first time with pics. I have a 2 pronged sensor (I think the "switch") screwed into the master cylinder. One wire obviously grounded to the MC housing and the 2nd wire going over to what looks like a relay. The relay is attached to the wires that are attributed to the brake circuit by the diagram provided by SPF, but the relay itself is not listed in any of the wiring diagrams. My question, is it the relay or the switch. Does anyone else have this relay? Anyway, thanks for any input.
| Buzzmobile |
10-10-2004 05:50 PM |
dang that pic is small..I will try and post it in my gallery
| Michael C Henry |
10-10-2004 06:28 PM |
If there is a relay maybe one wire is to ground but on mine one wire is hot the other goes to the brake lites.
Question do you have seperate brake and turn signals.If yuo are using the same side of the same bulb for both you would have to have a brake signal canceler in the turn signal switch.
Probably a bad brake sending unit--the round thing with the wires attached to it--they do fail every once in awhile, they can cause any number of intermittent or outright failures of rear brake lights working or not when they start to go bad.
| All times are GMT -7. The time now is 03:33 PM. |
