-   Shop Talk (http://www.clubcobra.com/forums/shop-talk/)
-   -   Combo Rect. Rear Lights Stop & Signal? (http://www.clubcobra.com/forums/shop-talk/68919-combo-rect-rear-lights-stop-signal.html)
bamcoc5 04-23-2006 11:57 AM
Has anyone modified their rear rect lights so an extra bulb can be used for turn signals?
Bruce
pmfranke 04-23-2006 02:24 PM
good idea. take some pictures when you do it.
Roger Bolick 04-23-2006 04:15 PM
No, but likely a better solution is the LED right angle bulb thing that plugs into the existing socket. This provides a much brighter light with much less heat. Heat being a big issue, I've heard of paint/body damage from the heat of these things if for some reason the "bright" is left on (signal or brake stuck).
I would like to see info on the LED experiment. Search for someone else numbers, etc.
Three Peaks 04-23-2006 07:20 PM
I thought I saw a post awhile back that showed a Superformance that had the dual bulb modification. I wonder if Superformance would sell these lights?
cobrajeff 04-24-2006 06:05 AM
Rectangular lights with dual bulbs
I bought a set of tail-lights from a Superformance dealer and installed them in my ERA. I opened up the holes in the body, and the holes in the lamp retainer to maximize the lighted area. I rewired my car to separate the turn signal function from the stop/tail-light functions. I also used a Halogen bulb for the stop-light bulb to make it noticeably brighter. Here's a sketch showing before and after:
http://www.clubcobra.com/photopost/d...170lights3.jpg
regards,
Jeff
bamcoc5 04-24-2006 07:03 AM
Thanks Jeff.
jarendall 04-24-2006 01:54 PM
I modified my wiring so as to have emergency flashers, I also made an aluminum box, very similar to the one shown above, to cover the bulb and reflect the light outward, I drilled a hole in the top and bottom of the box to allow air to circulate, I am still using the single bulb set up
