Shop Talk
http://www.clubcobra.com/forums/shop-talk/)
| double ugly |
07-07-2006 09:51 AM |
Correct gear lube for a Dana 44
I have an AMP IRS on my car. It uses a Dana 44. Which gear lube would you recommend for AZ driving? I also would like an opinion on the correct transmission fluid to use in a TR 3550. As always, thanks alot.
John
| kris-kincaid |
07-07-2006 03:44 PM |
Did you change out your diff? It was a 9" Ford when Neil had the car. On the Dana 44's I use the friction modifier from a Chevy dealer.
| double ugly |
07-07-2006 04:30 PM |
George Petrus said its a dana 44. Isn't that the gearing?
John
| kris-kincaid |
07-07-2006 04:37 PM |
George must have forgotten, he does make the adapters to put a Jag (Dana 44) diff into a Hi-Tech chassis. Your car has the 9" Ford. :)
| double ugly |
07-07-2006 04:56 PM |
Kris, which gear lube in the Ford 9"then?
| ENTDOC |
07-07-2006 05:32 PM |
moroso climbing gear oil
| double ugly |
07-07-2006 08:52 PM |
Thanks, John
| All times are GMT -7. The time now is 07:58 AM. |
