SUPPORT OUR SPONSOR
December 2025
Old 07-30-2006, 08:16 AM
55312's Avatar
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
Default Tonneau / Top stud repair
I'm sure I can't be the only one to have this happen so here goes.........one of the studs for securing the tonneau and top has come loose on the driver side door. It just pulls out as the hole is now too big for the threads to bite. I put a dab of epoxy on it last night and hope it does the trick. If it doesn't, how have any of you fixed this kind of problem? Do they make these studs with regular treads for a nut and washer? Do they make over sized threads? I can get at this one if I take the door liner out.
All input is greatly appreciated.
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
Old 07-30-2006, 08:27 AM
Cashburn's Avatar
Backdraft Racing Dealer
Need to know what type of stud you have? Do you have any photos?
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 07-30-2006, 08:40 AM
A-Snake's Avatar
Original Shelby Owner
Cobra Make, Engine: CSX2321
Tim
Yes they do.
Lift the DotŪ stud, 8-32 X 5/8" machine screw. Stainless Steel Nuts and Washers available.
http://www.beaconfabric.com/vindex.html?cat200.htm
Old 07-30-2006, 02:48 PM
55312's Avatar
Jay - No photos
A-Snake - PERFECT! Thanks!
Tim
Old 07-31-2006, 06:03 AM
JCoop's Avatar
Cobra Make, Engine: Superformance, FRP460 Big Block
Good since Tim's problem is solved, maybe someone can help me on a similar note...
I was told but with no source that a Lift the Dot stud that will hold 2 females is available. Now now, don't get your imagination go too far
The vinyl fender spats on my SPF uses the last stud near the door to secure the top part; and with them on, I can't use that last dot for the tonneau cover or the soft top. I've searched all over and no luck.
Thanks!
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 07-31-2006, 06:37 AM
Rick Parker's Avatar
Yes they make the studs that are longer. I found my supplies at a marine oriented upholstery shop. They can be had with a machine screw thread and a self tapping type thread. TRW markets them under the descriptive name of "Dot Snap Fasteners". Hope this helps. The more common name is "Lift the Dot".
http://www.indexfasteners.com/product/dot/dltd.htm
Rick
HTML code is On
