SUPPORT OUR SPONSOR
December 2025
Old 08-24-2006, 11:51 PM
Cobra Make, Engine: Backdraft #486 402r This is my 2nd backdraft.
Default Late night trip home on a flatbed
Driving in a spirited manner last night the motor kind of rattled a bit and quit. I would appreciate any guesses as to the cause. It was not hot, and would turn over well, but other than that I don't know much.
Paul
I have been corrupted by perfume and gasoline!!
Old 08-25-2006, 01:08 AM
Aussie Mike's Avatar
Pull off the dizzy cap and see if the rotor turns when you crank the motor. Could be a broken distributor gear.
If that's OK look and see if you have fuel, spark and compression. A quick check with a compression tester will tell you the state of each of your cylinders.
Pull a plug and laying it on the rocker cover with the lead connected and crank the motor. You should see a nice blue spark across it.
With the air cleaner off have a look in the top of your carb open the throttle and see if the accelerator pump shooters squirt fuel. (don't crank the engine whilst doing this as I've seen people lose their eybrows to a ball of flame).
Mike Murphy
Melbourne Australia
Old 08-25-2006, 06:12 AM
Tommy's Avatar
I agree with Aussie Mike, but I'd check the carb first just because it's so easy to do.
Tommy
Previously owned EM Cobra
Old 08-25-2006, 06:55 AM
Aha!! No dizzy in the dizzy !! I will pull the distributor and see if it is the distributor.
Paul
P.S. Boy would I be screwed without this forum.
Old 08-25-2006, 07:41 AM
If the timing chain broke did I bend a valve?
Paul
Old 08-25-2006, 08:30 AM
Wayne Maybury's Avatar
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
I assume from your last reply that your rotor is not turning. Most likely the problem is with the distributor gear. A broken distributor gear should not result in any damage to the valve train. However there could be lots of crap from the broken gear inside the engine that has to be cleaned up.
If the timing chain has jumped a tooth or worse still, broken, you very well may have bent some valves and or push rods. If you think this could be your problem, remove the valve covers and check that all the valve stems (for those valves that are not open) are at exactly the same height. If any of them are down a bit, they are probably bent. If any are up a bit, they are probably broken. Also check all the push rods to make sure none of them are bent.
A compression test will confirm bent or broken valves as the compression on those cylinders will be zero. Be careful craking an engine too much, that has this type of damage as you could make things worse.
Wayne
Don't get caught dead, sitting on your seat belt.
Old 08-27-2006, 10:12 AM
Yahoo!! It's a broken distributor gear!!
Paul
Old 08-27-2006, 11:09 AM
mike knight's Avatar
Cobra Make, Engine: spf 1837 408w 93mm turbo
Send a message via AIM to mike knight Send a message via Yahoo to mike knight
don't you love it when what your hoping to see is exactly what it is. something that wrecks a couple of hours of enjoyment and flattens the wallet a little bit but is within the repair realm of the majority of us garage mechanics.
right now i've developed a rattle in my external fuel pump. i'm thinking its the brushes are worn (way premature with only 500 miles on this pump). i bought the pump used/rebuilt and maybe this is a problem with this particular weldon pump.
did the gear frag? how much tear down is required for you?
mike
BAD ASP
spf 1837 408w intercooled turbo t56 viper 6spd
95 mustang cobra 408w vortech t trim supercharger
71 torino cobra 429 scj
66 ford galaxie 7 liter
68 buick wildcat 430
Old 08-28-2006, 10:31 AM
dsmith's Avatar
Cobra Make, Engine: ERA #63 428FE
I too went for a flat-bed ride with a bad distributor gear. Check down a ways in the posts "brass distributor gear" and there will be somne advice from forum users that may be of help.
HTML code is On
