-   Shop Talk (http://www.clubcobra.com/forums/shop-talk/)
-   -   Inertia Activated Fuel Cut-Off Switch (http://www.clubcobra.com/forums/shop-talk/72357-inertia-activated-fuel-cut-off-switch.html)
MFE III 08-29-2006 04:23 PM
Anybody know of sources for an inertia fuel pump cut-off switch? Some posts have indicated they are readily available from junk yeards, but I'm more inclined to install a new one. I've checked the usual suspects (Summit, Jegs, etc.) and only found one for about $65 from Pegasus.
Thanks
matt
niles 08-29-2006 05:44 PM
I had the same thought when I built, only my searach for new OEM switches were all over $100.
All late model Fords use them; I found a brand new totaled Ford sedan and got it for $5. They are usually located in the rear side panel at the rear.
Works perfectly .
gn
Michael C Henry 09-02-2006 07:38 AM
I bought one through Ron Franscis Wire Works. I mounted it to the drivers door front hinge post. Where I figured it would be most likely to be needed and reachable for reset. I also installed a Flaming River multi function master switch in the middle of the dash so I and anyone else could reach it. Twist to engage and bump inward to disconnect. I can't remember where but I do remember EM mounting their fuel cutoff switch some where clever.
sllib 09-03-2006 06:31 AM
Matt;
Did you try any of the fuel cell builders?
Bill Stradtner
