Setting the timing question with pic attached
When setting the timing on my 351w from which point do I measure TDC from? Also is timing set from the same point. And last but not least will an inductive timing light be sufficient?
Paul http://pg.photos.yahoo.com/ph/paulmc...?.dir=/aea8re2 |
the pointer or in the picture, the stright edge, is for timing, the brighter the light the easier it is to see the mark, I think the hole is for using a timing light that has the advance timing feature built it
| All times are GMT -7. The time now is 12:37 AM. |
