Need Help
Cooked My Starter On My 351w Motor
My Question ,it Has Been 6yrs Since I Bought My Starter And Didn't Write Down The Teeth Count And Can Remember How Many Teeth Are On The Flywheel' The Code On The Flywheel Is C5ae-6380-e Can Any Member Help Me Out With Any Information Thank You Cobra 36 |
...moved to Shop Talk
I can't help you on the flywheel thing, but if you need a starter, get one from these guys...
http://www.robbmcperformance.com/ The best starter you'll ever buy. |
Most 351W with a manual transmission use a 154 tooth flywheel.
Jegs also sells the high torque starters, if it is a stock flywheel, then the starter should be a direct replacement for the stock starter, do a web search on the numbers you have
| All times are GMT -7. The time now is 10:32 AM. |
