Old 10-18-2006, 07:14 PM
Tenrocca's Avatar
Default Door opening - sill - trim and finish
Gday,
Im after some pics of how the door sill (bottom edge of the opening) is finished off. Also around the lock striker and towards the rear cowl of the cockpit, and around the door hinges. The body of my car (which is similar to an Everett Morrison) has a sharp edge around the door opening, and I want to glass in a proper sill and finish off the back edge, and around the door hinge as neat as possible.
Thanks in advance.
Andrew
Old 10-19-2006, 08:13 AM
Roscoe's Avatar
I got a piece of angle aluminum from Homo Depot. I heated it to take the temper out and make is soft as butter. Shaped it and secured it with button head screws. Then polished it up.
Roscoe
Old 10-19-2006, 11:45 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Roscoe, is that a pretzel next to the seat there?
I still haven't figured out what to do about mine.
Old 10-19-2006, 11:48 AM
Roscoe's Avatar
A pretzel? I think you are referring to my sunglasses sitting in an upside down hat.
Although I do like pretzels....
Roscoe
Roscoe
Old 10-19-2006, 12:06 PM
w-lewis's Avatar
Cobra Make, Engine: Unique, 351W
Sterling Motorcars, in Virginia has a nice looking SS door sill molding.
Old 10-19-2006, 01:59 PM
1985 CCX's Avatar
Door sill,
I used aluminum from the local Ace Hardware store. 3/4 x 1/16 x 48" times two. The stuff molds easily and is easy to install and polish. Pics in my gallery a page or so back.
Good luck,
Jeff
Old 10-19-2006, 04:01 PM
SuperHart's Avatar
Send a message via AIM to SuperHart
Home Depot carries aluminum strips in the floor covering department designed to cover the seam between two carpets. The strips are 1" wide. I bought two strips, bent them into shape using the propane tank from my grille as a buck, cut them to proper length and secured each strip with #6x1/4" stainless sheet metal screws. They are a cinch to keep shiny with an occasional rub with 4-0 steel wool. Total cost, less then $3.
Old 10-19-2006, 05:30 PM
Tenrocca's Avatar
Thanks Guys (No home depot down under - we got "Bunnings" or "Hardwarehouse"). I reckon Ive got the sill area sorted, but if anyone has pics looking back at the door striker to the rear cowl, that would be great.
