Shop Talk
http://www.clubcobra.com/forums/shop-talk/)
A-arm question
http://www.clubcobra.com/forums/shop-talk/74358-arm-question.html)
| Janusz |
11-10-2006 10:52 PM |
A-arm question
Installing a new set of upper a-arms, that have the nuts on the ends of the cross bolt that is attached to the chasis. If I recall, you are supposed to tighten these so as to load the upper arms. When they are tightened, they lock the arm to the press fit rubber bushing in the arms.
I can' recall whether these get tightened when the car is sitting level. Does anybody know of what position the arms need to be in when these are tightened up? Thanks.
| strictlypersonl |
11-11-2006 04:57 AM |
Tighten the nuts when the car (on it's suspension) is at normal ride level. That means that normally there will be no bushing preload.
| Janusz |
11-11-2006 05:59 AM |
Thanks. Appreciate the prompt reply.
| All times are GMT -7. The time now is 10:25 PM. |
