Old 12-08-2006, 10:31 AM
Dwight's Avatar
Question disc brakes & master cylinder problem
My friend has a Cobra with Lincoln rear 11" disc, Mustang front disc and two 3/4" master cylinders. The problem is weak brakes that improve if pumped several times. After we bled the brakes, With the brakes applied, I could turn the rear rotor. I think he needs a larger master cylinder for the rear and adjust the balance bar. What do you think?
Dwight
Old 12-08-2006, 10:35 AM
Send a message via AIM to mj_duell
Dwight
That is true, the larger cylinder I mean. I used a 1 inch front and 7/8 rear on my A&C.
--Mike
Old 12-08-2006, 10:49 AM
Richard Hudgins's Avatar
Dwight
You need to smaller on the rear MC, not larger.
Best regards,
Richard Hudgins
Old 12-08-2006, 12:08 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I had the same setup...exactly. Mustang II fronts and Lincoln rears. I have to put 7/8" master for the rear and 3/4" for the fronts. Then I adjusted the balance bar from there.
The Lincoln has a large surface area and work well...once the system is balanced.
Just my $0.02
Dang, maybe it was the other way around.
Old 12-08-2006, 02:22 PM
Clois Harlan's Avatar
I have tried it several ways including the way some of you have mentioned. Richard is right, go smaller on your rear Master Cylinder. I used a 3/4" rear and a 7/8" front. I am running Wilwoods in the front and Explorer rear calipers.
Oh yes, Keep bleeding because you still have air in your lines (check all your connections again).
Clois
"Let's roll"
"Be part of Something Good
Old 12-08-2006, 03:03 PM
undy's Avatar
I run a 5/8" front brake master cylinder, but I don't think M/C size is your problem. It's an improperly adjusted balance bar. Before you start juggling master cylinder sizes adjust the balance bar for more rear brake bias. Tilton has a real good set of instructions on their web site. All this is assuming that both systems have been been bled properly and your rear circuit is not air-bound.
I'm getting ready to do a Wilwood 12.19" 4 piston conversion on my fronts. I'm currently running Exploder 11" rear rotors/calipers and my fronts are GM metric calipers on Mustang II spindles/11" rotors. The 5/8" M/C gave me the front brake stopping power I needed. I may need to go with a larger front M/C with the Wilwoods.
Dave
Too many toys?? never!
