SUPPORT OUR SPONSOR
December 2025
  #21 (permalink)
Old 02-25-2007, 05:47 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Ok so does any one know the answer to the original question regarding a 351W?
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
  #22 (permalink)
Old 02-25-2007, 08:22 PM
Rick Parker's Avatar
Take oil from the engine (outer hole, check your remoter adapter) to the oil filter (IN) then from the filter (OUT) to the cooler inlet (either side), then from the remaining cooler port back to the engine inlet at the remote adapter (center). Use a minimum size #10 AN hose with as few 90 degree AN tube bends fittings as possible. Plan your hose route carefully to avoid possible abrasion and at the same time keeping its length as short as possible.
Check out the filter adapter used from a mid 70's 460 Engined Ford Econoline van (may be used in other OEM applications too, it is very compact) it will allow you to mount the filter at about a 30 degree angle close to the block and by modifying it slightly provide the ability to attach the hoses to the cooler at the same time. This is a very good and often overlooked filter adapter that can be used on 260,289,302,351w,429,460. This is one on Ebay currently.http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWD1V
Rick
Display Modes
HTML code is On
