SUPPORT OUR SPONSOR
December 2025
Old 03-04-2007, 08:42 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Fuel line bead
Is there a simple way to bead a fuel line, without buying a beading tool?
Tool runs about $30 plus shipping - Not something you use all the time and to make just a couple beads, I thought I'd ask.
Do I plunk down the $$$ or is there a way to get a bead? Just a flare at the end of the tube isn't very professional.
Paul
www.65shlb.com
www.prdcrrct.com
Old 03-06-2007, 10:07 AM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Use these, I got mine from Summit.
"Fitting, -6 AN Female to 3/8 in. Tube, Aluminum, Red/Blue, Each
A little tip is to put some gasket maker (just a very small dab) on the outside end of the tub and this will almost ensure a perfect seal. You can use the same stuff you used for the gas tank assembly. Otherwise I found these tend to leak a bit with out it (3 of my 4 did without the little dab). Overall, much easier than a flaring tool and fittings.
http://store.summitracing.com/partde...=RUS%2D639200& amp;N=700+115&autoview=sku
The right fittings for the job.
Looking for the right adapters to use with aluminum fuel line? Then look no further than these adapters from Russell. Designed to connect aluminum tubing to -6 or -8 AN adapters, their unique crimp design eliminates the need to flare the tube, thus saving you precious time. They're available with both male and female ends for 3/8 in. or 1/2 in. diameter tubing. "
Old 03-06-2007, 10:17 AM
Rick Parker's Avatar
What type of fuel tubing are you using? Aluminum, stainless? Are you putting a rubber hose onto a metal tube with a hose clamp?? If you are attempting to prevent a hose from coming off, it can be done with a simple slight flair on the end of the tube, or a ferrulle (sp?) could be slipped on the tube and soldered in place. I have done both successfully.
Rick
Old 03-06-2007, 04:29 PM
Aussie Mike's Avatar
Attachment 12506
I used these fittings on the 1/2" aluminum hard line from the tank to the engine bay. Another thing to watch out for is how much tube extends past the brass olive before you tighten it up. I had trouble getting one to seal properly. The olive was compressesd onto the tube OK but the end of the tube was bottoming out in the fitting and preventing a good seal. Trimming a few mm of the end of the tube fixed it up.
The rest of my lines are flared with tube nuts and they seal great. Not difficult to do either.
Mike Murphy
Melbourne Australia
Old 03-06-2007, 06:22 PM
ItBites's Avatar
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
How about a B-Nut instead?
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
Old 03-06-2007, 06:29 PM
PaulProe's Avatar
I'll bite - what's a B-Nut?
www.65shlb.com
www.prdcrrct.com
Old 03-06-2007, 06:51 PM
ItBites's Avatar
Tube sleeve (ferrule?) and associated nut slid over the tubing. Then flare the tubing... I am sure you have seen them.
E. Wood
ItBites
HTML code is On
