Old 05-28-2009, 09:12 AM
onefastmustang's Avatar
Default Bonding AL to AL
I have two pieces of aluminum I need to bond together. There will be no stress between them once fully assembled but they do need to be secure and fluid leak free. Any suggestions on an epoxy?
Old 05-28-2009, 10:26 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Pop rivets and Sumo glue should do it. That is as long as the fluid does not desolve the glue/sealant.
Just a suggestion.
Old 05-28-2009, 11:03 AM
Karl Bebout's Avatar
JB Weld works miracles.
Karlos
Old 05-28-2009, 11:16 AM
Doug I's Avatar
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
You can't weld it?
Pull a gear .... drop the hammer .... and enjoy the Drive !!
Old 05-28-2009, 11:43 AM
http://www.lord.com/Home/ProductsSer...8/Default.aspx
Old 05-28-2009, 12:10 PM
mrmustang's Avatar
Gold Star Contributor
3M makes a wonderful two part epoxy for this called "Automix" part number 8115. Used mostly for bonding quarter panels and door skins, should work well with what you need it for.
Bill S.
Old 05-28-2009, 01:08 PM
Originally Posted by Doug I View Post
You can't weld it?
It's a very small part. I would be concerned with warpage from heat. I have gotten a few good ideas now though. thanks guys.
