Old 11-08-2009, 10:30 AM
Not that I (or many here) would not have made the same series of small misjudgements, but it does reinforce the "check everything first" philosophy. In this case, the correct action would have been to pull the belt and give a quick evaluation to the spin of the waterpump and alternator - maybe with a rubber wheel chucked in a drill. No particular noise or vibes? Look at the crank pulley, maybe even pull it off and look to be sure.
*Then* plunk down on replacement parts.
Gosh, this 20-20 hindsight thing is so EASY!
Old 11-08-2009, 12:47 PM
the little things have the biggest teeth..............
Old 11-08-2009, 07:17 PM
HOW FAR AWAY DID THE STETHOSCPOE LAND???
Or is that also going to be on your Pay It Forward List?
Craig
Old 11-08-2009, 07:20 PM
That's pretty funny.
  #25 (permalink)
Old 11-09-2009, 02:52 AM
Craig
Believe it or not, after 3 or 4 tries I got pretty good at it .... after 3 or 4 stethoscopes and an ear lobe later. I've been sorta hopin' that Pat might post his up.
Dave
  #26 (permalink)
Old 11-09-2009, 04:10 AM
Ron61's Avatar
Post
Glad that you found the problem and it wasn't anything really serious. I too had an experience using a stethoscope trying to track down a rattling noise. With the scope everything pointed to the front end and after taking the belts off I could still hear just a little of the metal to metal noise. Finally tossed the scope and got under the car and one of the exhaust pipe hangers was loose and it was viberating against the frame.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
