| 1 |
| 8 |
| 15 |
| 22 |
| 29 |
11-05-2009, 10:23 PM
Registered User
ca
Cobra Make, Engine: SPF#1751 CHP 427
145+mph
My company rent a run-way at Alameda Naval base for flight test simulation, since the run-way was too long & smooth, I decide to take the car out for fun/fast high speed run.
I have tried at least 6 times, but never able to reach 150MPH, top speed I can get around 145+, may be there it a limiter on my car.
May be I am chicken-out!!!
FYI
Myth Buster used this run way for their test-TV show.
Tan
11-05-2009, 10:26 PM
Myth Buster used this tun way for all of their test & show.
Tan
That's cool Tan! Did the car feel pretty stable at that speed? Any lifting in the front?
11-05-2009, 10:38 PM
Registered User
ca
The car feel very stable, and straight at the speed posted, I do not feel any lifting in the front, however there was a bit swerving on either 1st or 2nd gear if I push her to hard.
Tan
11-06-2009, 01:53 AM
Registered User
Tan - I think you are hitting an "air=wall" Aero-Dynamic issue at 145. --
145 is very respectable with a car that blows a .45-54 CD ratio.
( who has the drag coefficient numbers on the 427 bodies >? )
 -Nothing Beats a Live Fire Demo.
--Steve
1964.5 Mustang Convertible (5.0L ,T5, 4WDB)
SPF 2734 MKIII, Roadster (No Scoops/No Hoops) BRG (5.3L FR Boss 302 block , Ford X303 Heads, 93 Cobra Intake, A9L , 24lb, MASS AIR EFI)
CSX4985 (Building) - 428 Street Car, Silver/black int.
11-06-2009, 09:25 AM
Registered User
ca
I failed physic test @ college, therefore I could not figure this out
I recalled my old Corvette can reach higher MPH then my Cobra.
Like what I said, I possible chicken out!!!
Tan
11-06-2009, 11:33 AM
Registered User
Cobra Make, Engine: Shelby
Tan
your old Corvette likely had an optimistic speedo.
Z. Ray
'66 GT-350
Original Drivetrain, Sheet-Metal, Interior, & Paint
11-06-2009, 11:56 AM
Registered User
ca
The old Corvette has digital speedo meter, so likely more accurate then the analog on the Cobra. I may have passed the 150MPH threshold,but due to analog reading so it's hard to judge with large scale incremental.
Z. Ray
11-06-2009, 12:01 PM
Registered User
Remember -- in the end ; everything tastes like chicken.
I found something close to what i was looking for. -
http://www.mayfco.com/cobra.htm
scroll down to the charts.
He is using .42 Cd for his calculations which I think is optimistic. -- I think the open cobra is more like a .54-.60 Cd range.
I need to figure out how to figure that out.
--Steve
Rocket Scientist
--Steve
11-06-2009, 12:33 PM
Registered User
It's pretty hairy math. You have to begin by measuring/calculating the square footage of the frontal area. This is the easy part. One technique is to take a photo, from the furthest possible distance to flatten perspective and the longest lens available to bring the image close, with measuring references in the pic. Print large, outline the car surface, and measure measure measure.
Calculating or even estimating the Cd from there would be... entertaining.
The short way to do it is see if anyone's ever thrown a Cobra into a wind tunnel, or find a similar car that's been tunnel-tested.
.42 doesn't sound too far off, IME. He says "published figure" but doesn't cite the source.
Reason: Source of figure
11-06-2009, 12:54 PM
AL
Cobra Make, Engine: Lone Star 5.0 / 354 stroker EFI, 402 rwhp & 416 rwtq, TKO 600, YELLOW & over 27,000 miles and a 2006 Mustang GT
Tan
Do you know your horsepower?
Dwight
11-06-2009, 04:43 PM
145...150...Doesn't matter...You were still haulin' ass!
"...tires spitting gravel, I commit my weekly crime."
11-06-2009, 05:00 PM
AL
Cobra Make, Engine: E-M 427 light weight body, 410 Windsor
For comparison, my fastest speed on the front straight at Roebling Road racetrack was about 140 MPH. I exited the turn before the straight at about 100 MPH, accelerated full bore along the roughly 2,000 foot straight before hitting the brakes to slow to about 80 for Turn 1. My car accelerated strongly to near 140, but it felt like it would have taken a lot more straight away to reach 150. Keep in mind that at 140 MPH, you're traveling more than 200 feet per second. If it took 5 seconds to gain another 10 MPH, you'd cover more than 1,000 feet in that time, and your braking point would have to be moved back even farther because of your higher speed.
Tommy
E-M 66 427SC, Ford 410 Windsor, Richmond 5 speed, Corvette suspension.
Reason: Grammar
11-06-2009, 05:01 PM
Registered User
Cobra Make, Engine: E.R.A. 289FIA #2108
I've hit over 140 on a closed course with my ERA 289 FIA. 302 with a TKO-600, 0.82 OD.
It was still pulling at 140, but I was running out of runway. I think I can hit 150-155.
Yes, it was very stabile, even under heavy braking. Thrilling, to say the least.
DD
Dangerous Doug
"Do you mind? I can't hear my pipes with all your yack'n going on."
11-06-2009, 05:07 PM
DD
Would that "closed course" happen to be Hwy 17 in Scotts Valley with no other cars around?
11-06-2009, 05:11 PM
Originally Posted by Dwight
Tan
Dwight
I'm pretty sure Tan has a CHP 427 Street Fighter, which is just under 500 hp.
| Thread Tools |
| Display Modes |
Linear Mode
