12-27-2009, 08:25 PM
Broken Dove Rockers ??????
I would like to know from those of you that have had or are using Dove rockers.
Have you ever broken a rocker?
What was the cause of breaking the rocker, if known?
What is your lift on the camshaft?
What pressure springs are you using?
Cup size on pushrod?
Ball on pushrod?
I had 2 rockers break that I think is due to too much spring pressure.
Also would like to know what you did to correct it
12-28-2009, 07:18 AM
Ill
Your rockers did not break because of too much spring pressure---your rockers broke because the rockers aren't strong enough for your springs
12-28-2009, 10:39 AM
We had a member of the local club break a Dove rocker last year. You can read the thread here: http://www.capitalareacobraclub.com/...ic,7039.0.html and Jim later placed a pic of the sad rocker in his gallery. Here's the pic:
12-28-2009, 11:20 AM
Phil, you may have already done this, but if you do a search on "Dove" and "rockers" or just "Dove" over on the FE Forum, you will see many threads about problems with Dove parts including Dove rockers.
I have no personal experience with Dove. Sorry.
12-28-2009, 11:27 AM
This thread is virtually a repeat of the still-live one on the same topic, started by the same OP. I'm not sure why.
12-28-2009, 11:34 AM
Yes, but by starting a new thread he prodded me in to remembering that we had a similar experience locally just last year.
12-28-2009, 11:38 AM
I just wanted to see how many others purchase this rockers thinking that the would hold up to normal driving.
These Dove rockers are obvisouly junk.
My resolution is to move to Erson. Now, I hope this solves my problem.
As you can see from the thread (link) from Patrickt Dove stated it was backed for life.
The removed this statement from there website. Go figure!
12-28-2009, 12:26 PM
I've been running Dove rockers for a few years now and many thousands on miles. I doubt spring pressure is the problem. My old cam was a solid roller, motor would turn 7,000 rpm. Dual springs with a damper spring (three total), pretty high pressure springs, never had a rocker arm problem.
12-28-2009, 12:27 PM
I love my Ersons, thank you very much.
12-29-2009, 09:37 AM
Ewwww! Warn us if you're going to post pix of open-head surgery.
01-01-2010, 10:09 AM
OR
Cobra Make, Engine: Contemporary / FE
Hello Priobe
May I make some points of consideration.
First of all I do not advocate any brand or detract from any brand. I have used Dove, Erson, Precision Oil Pumps, and T&D. I have not had any problems with any of them that I believe was attributable to the rocker arm itself. But the problems I have experienced are relative to two things. (The below is pursuant to high spring pressures. To quantify 250# closed and 620# over the nose.)
1. If the lash adjustment screw is screwed where more than two threads are below the body of the screw hole this will put excess leverage on the body of the rocker arm thus causing breakage. Make your pushrods to the length to accommodate this.
2. Pushrod whip. If the pushrods are not stiff enough then when they whip this puts tremendous load on the rockerarm during opening ramp excelleration.
3. When using Dove rockerarms I change the adjusters to ones supplied by Smith Brothers for Chryslers that have a 5/16" ball. Changing your pushrods to work with the 5/16" ball also lets you move the pushrod cup closer to the rockerarm.
I hope this helps.
01-01-2010, 10:44 AM
OH
You may be on to something there. wow. thanks.
01-01-2010, 11:44 AM
KS
Cobra Make, Engine: Spf Shelby alu block
I have two sets of the Dove HD rockers (1.200” wide). with end stands. The oldest set is in a 427 that has 850 # of open spring pressure and the engine has seen 8500 RPM on the tach. I did pay close attention to the push rod length and had a custom set of manton pushrods made. No issues after 5 years. The second set is in a 427 that only truns 7200 RPM with 550 # of open spring pressure two years old, no issues. Custom manton push rods in this engine also.
SPF 2551 Lyle
01-06-2010, 08:27 AM
Besides the pushrod being too short and creating some extreme leverage issues when the valve starts to open, two other things come to mind for the Dove (and similarly designed) aluminum rocker arms. The first is the age. Ten years of use is what I see as the limit before the rockers are 'fatigued' and just simply break. The other is side clearance. If the side clearance is inadequate, then when the rocker heats up and expands this creates a significant drag at the sides and puts it in a bind. I like a minimum of 0.030" of sideplay for the rockers.
I ran the bronze bushed aluminum rockers many years ago and had breakage issues from the start when using them with roller valve spring pressure requirements. I subsequently went with the Dove's and that particular issue went away but the breakage issues resurfaced when the rockers got several years worth of running on them. Just food for thought.
Ted Eaton.
Fe's are fast but "Y-Blocks" are fun when they run in the 9.60's at 135 mph.
01-06-2010, 08:50 AM
SPF 2551 Lyle
SPF 2551,
Is this a drag motor... pressure at 850 open is pretty agressive. Also how old are these rockers.
After the first rocker broke I rechecked everything( not saying I am perfect) I really dont think it was a push rod length issue because everyone I spoke to including Dove said to make sure you have 3 threads out.
Now, I finally switched to the Erson and noticed just by changing to the Erson rockers I had 5 -6 threads at the bottom of the rocker. Many have said it should be fine and I probably would not have a problem.
Well, I decided to remeasure the pushrod length and to have the 2 -3 threads on the bottom of the rocker with the Ersons. I then cycled the motor several times to make sure the cup is not touching the bottom of the riocker.
It will cost me an additional $200 but will save me a possible tow home.
Its funny, since I had down time I decided to check a few things. If my push rods were at 8.926 and I had 5-6 threads at the bottom. Each thread being .050 I could have easily add .100 to my existing push rod .
My final pushrod length needed for me to have 2-3 threads were 9.037 (EA) or 9.197 for a overall length
01-06-2010, 01:41 PM
MI
Sorry I could not get back to you on this - I found myself badly tangled up in non-work stuff for a few days.
I think you did the right thing on pushrod length. 5-6 threads is more than I like to see - I prefer 2-3. I measure my pushrods "bottom of cup" - using a modified pushrod length checker with a flat at the cup end and a 12" dial calopier.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
01-06-2010, 07:36 PM
KS
The rockers are 8 years old but have only been used the last 5 years. I just pulled the engine to freshen it up and the rockers look fine. The engine is in a street car. You can never have enought cam.
SPF2551 Lyle
01-07-2010, 05:52 AM
SPF2551 Lyle
Just curious,
What is your cam spec to be running those types of spring pressures?
01-07-2010, 07:04 PM
KS
I have found running a lot of spring pressure keeps the valve from bouncing on the seats and keep harmonics in the valve train down. I do run stainless valves 2.25 & 1.75 which are a little heavy. I also have tapered chrome moly push rods 7/16 x 3/8 which are a little heavy also. if you are going turn a little RPM you need to have good part. since it is just street toy I did not go with titanium parts so the heavy springs. Lift in. 774 ex.739
dur @50 in. 290 ex. 298. 15.7 to 1 compression two HP 950's over 800 HP
SPF2551 Lyle
