Old 01-20-2010, 09:44 AM
Default water pump hose
My 427 has a water pump inlet of approx.2.1 inch and a bottom rad. opening approx. 13/4.I want to use a zergo chrome flex. hose but I need to reduce the pump opening to fit. What can I do/ Thanx my friends
Old 01-20-2010, 10:01 AM
Have a radiator shop weld on a 2" outlet. Any other solution with spacers, adapters etc. is likely to look crude and leak.
Old 01-20-2010, 11:47 AM
they should have an adapter that fits the 1.75 radiator hose fitting that will increase it to 2 inch..........this was common back in the day when they made 1 radiator for 6 different cars.........call the mfg. of the hose company you want to use they should be able yto hook you up or check with your local radiator repair shop they may help also.
