Old 02-01-2010, 04:32 PM
Default Turkey pan
I am building an ERA with a 428. I have a single plane Victor manifold with a turkey pan. The turkey pan hits the hood. It looks like there is about a 1" interference. The turkey pan height is about 4 3/4 high. Does anyone know of a shorter pan?
Thank you,
Clyde Johnson
(314)705-2743
Old 02-01-2010, 04:42 PM
The Victor is a pretty tall manifold. The originals, and most current cars, stay with a mid-riser like the Blue Thunder or a Performer RPM for a reason.
I'd guess you're either going to have to go without the pan - and I'd wonder what air cleaner will fit, in any case - or cut one down to a height that will fit.
Old 02-02-2010, 10:13 AM
Your carb air cleaner is probably going to hit once you cut down the turkey pan anyway. You need to see if there's enough clearance without the pan. Sad to say, you may be in for a manifold change.
dave
Old 02-02-2010, 01:45 PM
CC Member / Sponsor
You can check hood clearance with a blob of clay...
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 02-02-2010, 02:22 PM
I can make or customise a Turkey Pan to your requirements. See how the air cleaner works by itself for clearance first.
http://www.actoncustom.com/
Old 02-02-2010, 03:21 PM
The banging noise is a pretty accurate gauge as well.
