Old 07-04-2008, 04:07 AM
BMK's Avatar
BMK BMK is offline
Question AN sizing
Hi all,
Just looking at the catologue for AN fittings.
Does anyone have a size chart for AN.
What is 10 AN or 12 AN in imperial sizing..
AN is Army/Navy but I can work out if AN 12 is 1/2" etc.
Any list or link to a site would be good. I have checked Russell and Earl to no avail - if I'm looking in the right place..
Old 07-04-2008, 04:57 AM
You take the number and divide by 16.
So, 12 AN is 12/16 or 3/4"
Old 07-04-2008, 05:11 AM
xracerbob's Avatar
Cobra Make, Engine: ERA 758 KC Pond 482
The Aeroquip site has lots of good info. On this chart they show OD and ID sizes of the various hose sizes.
http://www.aeroquip.com/media/perfor...001-E-p5-8.pdf
Old 07-04-2008, 07:10 AM
SuperHart's Avatar
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Dividing the AN number by 16 only gives you a rough idea of the actual inner diameter size. An AN-12 hose is not EXACTLY 3/4" in diameter so don't try to push an AN-12 hose onto a 3/4" hose fitting. That's why you can also find actual 3/4" braided steel hose for heater use, etc. The two hoses are not interchangeable. Conversely, don't try to use 3/4" braided hose with an AN-12 fitting. As already posted, the AeroQuip site has a handy sizing guide to help you.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Old 07-04-2008, 09:16 PM
AN is for tubing and fittings with 16 = 1". pipe is measured by the inside diameter opening and tubing is the outside diameter of the tube itself.#3 = 3/16" , #4 = 1/4",#5= 5/16", #6=3/8", #8=1/2" #10=5/8", #12= 3/4",#14=7/8", and #16=1", and so on.
Mike H
Old 07-05-2008, 07:39 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
BMK
I have a chart on page 141 in my book, "Racing Engine Builder's Handbook". If you don't have a copy of this great book following are some specifics. As was said, the dash number is pipe size in 1/16". ID for -10 and -12 AN hose is 9/16" and 11/16", respectively. I think Carroll Smith covered this subject in depth in his book on Racing Hardware.
Check out this sight for loads of good stuff from coolers, to AN fittings to Fuel filler caps. http://www.batinc.net/mocal.htm
Specific to your question, check out this page: http://64.202.180.37/files/tchart.pdf
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 07-09-2008, 02:48 AM
BMK's Avatar
BMK BMK is offline
Thanks all.
I have followed the links and it now makes sense - or better sense. I thought I was on the right track but this confirms it.
Mmm now to spend some money..
Thanks again guys
