Go Back   Club Cobra > Engine Building, Tuning, and Induction > Ignition
Old 03-20-2010, 05:59 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Can't get the engine to fire................Help, please.....
I am still trying to get an engine start and have been for 9 "LONG" months now.....
Here is the scenario.......
Ford 1989 5.0 motor.......MSD distributor (direct replacement for the stock Ford unit).....Crane coil.....Crane Hi-6 ignition box.....Miceotech LT10 ECU.
I have checked, double checked, and triple checked "ALL" of the wiring using the Microtech, Crane-hi6, and several troubleshooting wiring diagrams that are applicable, and have it just as the diagrams indicate.
The LT-10 self test mode fires the injectors and indicates no problems. The relevant lights on the LT-10 are Green and Amber, which are supposed to light upon power and the amber is supposed to indicate pulse ( I assume by blinking) during cranking. They both come on when power is applied but "GO OUT" while cranking.
The Hi-6 "RED" light comes on when the ignition is turned on, and blinks briefly as the igntion is turned off. According to the instructions it is supposed to blink while cranking, indicating it is receiving a trigger signal. It goes out during cranking. Also, according to the instructions, it can indicate different codes for troubleshooting, however none of the codes are displayed.
The coil sparks when the ignition is first turned on and sparks, with a beep, once or twice when the ignition is turned off.
I have called the shop where I bought the LT-10, several times, and the tech has not been very helpful on the phone. He wants me to trailer the car the 60 miles over to his shop so he can try and figure it out. He was supposed to come to me, twice in December, but was a no show both times.
I was given the name of a tech at a shop in Miami and called several times to talk to him, but he has always been too busy to talk and has not called back as promised.
Does anyone here have any ideas as to what the problem might be??
Thanks in advance for any information.
Safe Flyin, errrrr Drivin, Earl
