| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
31 |
12-29-2011, 06:56 PM
Registered User
KY
Originally Posted by AL427SBF
For future reference though, and for anyone else reading, a 454-460W is nowhere near the bore/stroke limits for a Dart block
As long as you stay with Iron right? The Aluminum DART has a recommended max bore of 4.165 (.020 less than Iron), hence you are limited to ~450 max CID on the Alu block. Just asking so I understand.
You could get up over 460 cubes with the aluminum block as well. Dart says they will allow 4.165" x 4.250" with those blocks, which would be 463ci.
I've never had to take any of these blocks out to as far as we're talking. I generally do the 4.125" and 4.155" flavors. As I said, sometimes customers get hung up on numbers and instead of a 427 (4.125" x 4.000"), they'll want a 434 just to be a little different.
Rod, yes, at some point you would look to a big block. I wouldn't necessarily look to an FE, but the 385 series engines will make unreal amounts of naturally aspirated horsepower and torque. Of course it all comes down to what you want, what you're doing, the style you want, etc.
www.b2motorsportsllc.com
Advertising
12-29-2011, 07:24 PM
Registered User
CA
Cobra Make, Engine: JBL Competition Roadster, Small Block Ford
Thanks Brent, good to know
12-31-2011, 08:26 PM
Registered User
RI
Cobra Make, Engine: B&B-359w-Keith Craft ported Brodix 17*heads-Jones Roller Cam-10.75:1cr-Pro-Systems 780-TR3550 5sp-Steeda Tri-Ax-McLeod clutch-Champ RR pan-Precision oil pump-Wilwood brakes
Dana what happened to the 393? It would seem like that made at least 500HP.
Lou
The KC Brodix is a very nice head. the 210 would fit nice with a 427. The AFR also is a nice head.
Lou
Lou
12-31-2011, 09:55 PM
Registered User
AZ
Cobra Make, Engine: Kirkham #684, 482FE
Go with the AFR head if your going the 427w route, in some cases the trick flow head, blykins knows best.
PRIDEnJOY
01-01-2012, 12:52 AM
Registered User
OR
Cobra Make, Engine: Superformance SPO2512 427W TKO 600/ NW Exotics 351 Cleveland/Tremec 3550-Sold
Lou
Lou
In the short time I had the 393 on the road, it sure drove nice and seemed to make good power.
The shop that built the motor used the wrong camshaft thrust plate resulting in excessive endplay. The cam and distributor gear were wiped out in less that 175 miles. I saw that he tossed in some used pushrods when he built the motor so I figured I better check everything. Crank, bearings, pistons and cylinder walls were undamaged. Measured all the clearances, CC'd the heads, etc. Everything checked out as per the build sheet.....except for the used, mismatched pushrods which were .080" too short, one of which was bent. That pretty much put me over the edge since by this time I had missed out on all the summer cruises, etc. I replaced all the damaged parts in the 393, a friend made me an offer on the motor to replace the 347 in his Mustang, so off it went.
01-01-2012, 07:15 AM
AL
Cobra Make, Engine: Lone Star 5.0 / 354 stroker EFI, 402 rwhp & 416 rwtq, TKO 600, YELLOW & over 37,000 miles and a RCR GT 40
We have two of Keith Crafts 408W in our club. They make 530 plus hp and 540 plus tq. Coach Mike has several thousands of miles on his, three years of driving year round. No problems. Very street-able motors, meaning they idle correctly, do not over heat, no oil leaks, no problems. Just drop in and drive.
I picked up the last motor a couple of weeks ago. 408W 531 hp & 540 Tq, cost $8375. If you will add up the cost of the parts your going to buy and the machine work, you will spend close to $8000. Keith uses parts that he has proven will work.
His shops are clean and orderly. He has all the machines needed to build a motor. We have five of his motors in our group and everyone loves them.
I can't say enough about the horsepower and dependable of his motors.
Check him out. Keith Craft Performance Engines
Dwight
01-01-2012, 09:10 AM
TX
Cobra Make, Engine: Lonestar, KC 410w
Both configurations are overkill for these cars. Get the one that's cheaper to buy, maintain and repair. I have a version of the Keith Craft 408 (not sure any 2 are exactly alike) and have not had any problem in 7 years 14k+ miles. Did a 260 mile cruise yesterday. Motor was flawless. Brakes need some work.....
Dave
01-01-2012, 11:02 PM
Registered User
OR
I'm going with the Brodix KC 210 heads for a couple of reasons: the exhaust port location is close to the location of the Dart Pro 1 heads that were on the 393 so the exhaust should bolt up without work and the Brodix heads outflow the AFR's...at least according to the published flow charts for both heads. I'll probably have my machinist check them on his flowbench.
I don't doubt Keith Craft builds a nice motor, but I prefer, and I'm more than capable, of building my own. It's my therapy. The one and only "crate motor" I bought in my life didn't make it 175 miles. My machinist friends are great. They know I have the tools to check the work as accurately as they can....and I will check.
Thanks to some serious shopping and some good deals, I can build an all new Dart block 427, with a forged Scat rotating assembly, using Keith Crafts' Brodix 210 heads and his hydraulic roller cam for about the same price as a factory block 408.
As Brent suggested, going bigger than 427" would not really cost much more for the engine parts, and you could make more power. In my case, I already had the new manifold and carburetor from the 393, I didn't want to shell out the dough to have new headers made and I don't have enough room under the hood to use a taller intake manifold. If I was starting from square one, building a 460+ inch motor would be very tempting. All in all if this motor can hit close to the advertised power numbers, not come apart on the dyno, and last more than 175 miles, I'll be happy.
01-02-2012, 01:50 AM
Registered User
RI
It should be a nice build. Keep us posted.
I found that my KC 195 heads raised my exhaust at the 4 pipe flange about 1/8". A 120 emery spool and a electric drill worked perfect to contour the body. Also the head valve cover rails were a little higher. The oil filler tube had to be cut 1/4 for cap clearance, again 5 minute job with a cutting wheel. I widened my Edelbrock RPM intake coolant passages to better match the head. The Aluminum heads have a shorter passage than the World Windsor Sr. which was taller. There is a thin tab in the intake coolant passage. It looks like it was meant for trimming. A quick port match showed that taking some [not all] of this tab away made for better coolant flow. Again very quickly done with a burr tool. I ran the car yesterday and all went well. I definitely felt the power difference through the whole RPM range. Check your Rocker pushrod geometry! I used the Mid Lift method and it worked great. PM me on this if you want.
Good Luck.
Lou
Lou
01-02-2012, 01:51 AM
Registered User
KY
If you don't have the parts, don't let the heads and intake stop you from adding cubes. Those 210 heads will work just fine on a larger engine and you can use the shorter intake. Torque is your friend in a street car...
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
