-   -   header gasket by Earl's performance products (http://www.clubcobra.com/forums/small-block-talk/114044-header-gasket-earls-performance-products.html)
tamanaco 01-19-2012 05:08 AM
My car had a set of earls performance products exhaust header gaskets. They also have parker pressure master p/n 29003a stamped on the aluminum gasket holder. I did some searching on google, didn't find any thing on this. It uses single rectangular gasket, that seem real soft, for each port, these are held in place by an aluminum plate about a 1/16 inch thick. This set up has worked flawless for the 6 years it's been on the car. I'd like to use this again on the stroke motor replacement. Anyone know if you can still find replacement gaskets?
tcrist 01-19-2012 05:49 AM
Try here Earl's Performance Products | StreetPerformance.com
Tom Cimino 01-19-2012 11:29 AM
I've had these gaskets for 15 years and they have performed flawlessly. Never loosened, never leaked. I recently had the engine out of the car and replaced the inserts when I re-installed the engine. I got the replacements from Summit. One thing to watch, The on-line catalog shows 8 inserts, but when they arrived, the package had only four. They sent me the additional 4 inserts at no cost. Summit Racing is a class act.
