| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
02-09-2013, 10:24 AM
Backdraft build - Diff question
Hi guys
My backdraft cobra build is underway and playing around with some diff ratios.
Any advise out there??
Specs:
Engine = Roush 427R
Engine rated = 550hp, but dyna shows 500hp @ 6000rpm
Gearbox = Tremec TKO600
Gear Ratio:
1st = 2.87; 2nd = 1.89; 3rd = 1.28; 4th = 1; 5th = 0.64
Tyres = 315x18x35
I am going for the progressive slip diff (just to avoid some of that 360deg recoveries).
Have been looking at the 3.9 / 4.11 ratio but not sure what will kill me first: the noise or the power.
02-09-2013, 10:42 AM
Tx
Cobra Make, Engine: CSX6128 with Shelby 468FE
Henkdt,
I would talk to Jay or Brian at Vintage but I am running the Coyote with a TKO 600 and 3.91 ratio.
I am pretty sure my previous BDR which had a 427R and TKO 600 was running a 3.63 ratio.
02-09-2013, 10:48 AM
thanks - how did she perform? power and fuel wise.
02-09-2013, 11:00 AM
Tx
It was a great combo. Loads of power and acceleration. Mpg was around 12 which was about what I expected.
I am no expert but I would have thought that the 427R with a 3.9 or a 4.1 diff maybe too much, particularly with all the torque that engine kicks out. The coyote is a lower torque, higher revving unit and the 3.9 suits it perfectly.
Andig
02-09-2013, 11:13 AM
Ut
Cobra Make, Engine: 66 Cobra
I was just working on a friends Shelby aluminum block 427 this morning for his Kirkham and we had this same conversation. With the .64 OD I would go with 3.50, but with the .82 OD 3.43. With the 3.9/4.11 gears first gear will be useless and and you are just going to spin the tires way to easy. So I vote for the 3.50s.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
02-09-2013, 12:23 PM
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
Plugging values into this tool and then building a spreadsheet (optional) will provide insights.
Second Strike Gearing Calculator
How you intend to use the car makes all the difference.
02-09-2013, 02:13 PM
With the 427 I would do the 3.46 unless you just like spinning tires in 1-3, and in that case, go with the 4.11.
If I had the Coyote I'd do the 3.91 or 4.11.
I have the 3.15 rear and spin too much in 1 and 2 during normal driving with an engine similar to the Roush 427R, but when the tires are heated up I start thinking that the 3.46 would be nice.
02-09-2013, 02:59 PM
Cobra Make, Engine: BDR354/FMS392
My BDR has the same TKO-600. My rear came from BDR as a 3:46 open diff. I switched it out to a 3:73 with 40% lock up. It is way better.
Because the 1st gear is tall at 2.87, you can run alot more gear in the rear without winding 1st gear out at a low mph.
I find the real problem is the .64 OD. The jump from 4th to 5th is just way to great. I really wish I had the .82 OD.
I never noticed a difference in gas milage between the 3:46 and 3:73.
02-10-2013, 01:22 AM
Gentlemen - this has been awsome feedback. And you have confirmed my worries.
Chilibit - great calculator.
The 3.4 to 3.7 range seem to be the sweetspot.
Now I can worry about the colour - CHEERS!!
02-10-2013, 08:38 AM
TN
Cobra Make, Engine: Backdraft, SBF 351w (463 CI)
Why do u want the .64 over the .82? U will eventually want a LSD diff.
Since u are going with a big V8. I would humbly suggest U go with a 3.46 and .82 OD (75MPH around 2750RPM). if U want a little more performance go with the 3.64 and stay with the .82 OD. (70MPH around 2750RPM).
02-10-2013, 09:03 AM
AR
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
3.46 is what I have. Unless you have drag radials, the lower gears are useless.
There were no atheists in the foxholes.
02-10-2013, 01:10 PM
NJ
Cobra Make, Engine: BDR #1230/B2 445CI SBF
I have drag radials and the 3:46 and it is still useless...I cant imagine a shorter rear end in the car provided we are talking 500hp plus. I was discussing a shorter gear with Brent due to the new engine we are building to help with "lugging" but ill just stay in 2nd through the neighborhood
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
02-10-2013, 01:12 PM
NJ
Sorry "useless" referring to RPatton3's post about the lower gears...
Gary Bowman
02-10-2013, 06:45 PM
Stolen Avitar
GA
I'm with those guys, 3.46 here, running street legal road race slicks and the lower gears of my TKO600RR are useless at anything above half throttle.
02-11-2013, 05:56 AM
OK
Just my point of view:
I have a 508 hp 408 stroker in a coupe with a TKO 600 with .82 5th gear and I have a 3.50 : 1 detroit locker. I will be replacing my gears with 3.73 : 1 for a little better overall performance. The current setup will spin the tires quiet well but coming out of a corner the increase in torque will help in the overall performance. I took the coupe to the track and found although the 3.50 gears work well a better combo would be going with 3:73 package. Granted, the 3:50 gears will yield better gas mileage but the 3:73 gears will improve track times. You can still cruise the freeways in 5th gear under 3000 RPM at 70+ mph. My redline is above 7000 RPM if I ever need those RPM's.
"Let's roll"
"Be part of Something Good
02-11-2013, 06:09 AM
Stolen Avitar
GA
Clois makes a good point here as mine is a 462" FE that'll never see over 6k RPM and it makes a ton of torque down low.
