-   -   3 Bolt Circle on Crank Pulley (http://www.clubcobra.com/forums/small-block-talk/120140-3-bolt-circle-crank-pulley.html)
Rick Parker 04-11-2013 08:52 PM
Is the 3 bolt circle on the Crank pulley for Ford and Chevrolet ever so slightly different? Chevrolet being the smaller??? I went to trial fit a pulley on Ford Spec ATI damper and the holes do not line up .030-.050 different???
FWB 04-12-2013 05:52 AM
yep, common on aftermarket balancers...i just open all three holes up on the pulley with the next size drill......
Rick Parker 04-13-2013 07:36 PM
Thanks, why don't they just make them the correct dimension instead of "One size fits all"?
LMH 04-13-2013 08:11 PM
China!
FWB 04-13-2013 08:33 PM
China? probably true, but this was still the case in the 80's, with aftermarket,
i look at it as laziness to engineer the part fully....kinda a modification from the GM part to just barely fit the Ford application,
look at MSD pro billet dist. its a GM modified, its too tall....for a rear mounted dizzy ok,...... but the front?
