-   -   NGK spark plug heat range (http://www.clubcobra.com/forums/small-block-talk/121564-ngk-spark-plug-heat-range.html)
CobraV8 07-26-2013 11:27 AM
Anyone has experience with this manufacturer? What heat range should be used as a starting point for 9,5:1 compression with Ford Duraspark Ignition?
Simon
PLDRIVE 07-26-2013 12:42 PM
I would start with a 6 or 7 (6 being hotter). But u can call or email NGK for better advice.
MP
ERA Chas 07-26-2013 03:18 PM
Yes, call their techline-very helpful
CobraV8 07-27-2013 11:16 AM
Thanks, will do!
Rick Parker 08-17-2013 08:19 PM
What reach plug do you require? Is it tapered seat or 14mm gasket style?
bobcowan 08-17-2013 09:50 PM
As a ball park figure, for every 100hp you add to the stock engine, you should drop one heat range from the stock recommended plug.
CobraV8 08-18-2013 02:22 AM
I ended up with the BCP7ES-11 (14mm gasket style). Engine is running strong, no fouling in stop and go also. Gap is set at 0.035"
PLDRIVE 08-20-2013 08:09 PM
Excellent
