-   -   Help Finding a Particular Steering Column (http://www.clubcobra.com/forums/small-block-talk/131945-help-finding-particular-steering-column.html)
AL427SBF 12-18-2014 08:25 AM
Trying to find out who makes this steering column -
Steel Tilt Steering Column, No Shift (A41GM PN 446-1232)
I thought it was a Flaming River unit but they say no. It's off a parts list that is 10 years old, maybe older. I can find nothing with google searches.
Bernica 12-18-2014 10:09 AM
Maybe from Ididit?
ididit Incorporated | Custom Steering Columns
vector1 12-18-2014 12:45 PM
That 32 at the end would indicate to me 32" column which sounds about right, what they came out with. Like I said, I went longer on the one, like long.
buckdono 12-19-2014 03:25 PM
Speedway Motors part # for GM Ididit column
AL427SBF 12-19-2014 03:40 PM
I'm not finding it, went to Speedway and Ididit websites, nada. Can you post a link to the actual column? With vector1's help looks like I have something that will work - 35" Floor Shift Tilt Column with 2" OD - Polished Finish - FR20007SS - 571 - 5350
Tommy 12-20-2014 03:58 AM
http://www.speedwaymotors.com/Ididit...FUQV7Aod_REAbw
AL427SBF 12-20-2014 07:04 AM
Originally Posted by Tommy (Post 1330675)
Thanks Tommy, looks like the Speedway site plays games with copying links but I found it.
Richard Hudgins 12-21-2014 11:39 AM
Brett,
I designed the chassis to use bespoke steering column parts. I used pultruded S-glass/carbon 1 inch shafts with bonded spline inserts and Borgeson joints.
Goodwinds is a good source for the pultruded parts. (Quite pricey of course.)
The upper and lower mounts were also bespoke alloy units w/spherical bearings made to fit the drivers angle and altitude preferences.
However, some folks wished a standard type column with turn signals, tilt and horn. The parts sheet that you were looking at is quite old and those numbers were from Speedway Motors years ago.
The current Speedway part #'s are:
Ididit 11-twenty-zed-thirty two-0020 Column (The written numbers are there due to the forum software not liking the number sequence **** for some unknown reason.)
Ididit 2401500040 Steering Column Ball Swivel Lower Mount, 2 Inch (footbox)
Ididit 2302470040 2.5 In. Steering Tilt Column Drop Mount, 2 Inch (upper)
Look at this page as there are many options for the drop mount that will allow you to put the column at the altitude you wish.
Hope this helps.
vector1 12-21-2014 01:29 PM
I marvel at some of the bespoke parts made for the JBL, the lower steering shaft mount with spherical bearing is one of them.
AL427SBF 12-21-2014 02:02 PM
Originally Posted by Richard Hudgins (Post 1330845)
Brett,
Hope this helps.
Thanks Richard, that is a tremendous help. Linak LA12 actuators and control we've discussed, for Brake Bias I'm showing Balance Bar Remote Cable INV-372-501 (Taylor Race Engineering), any changes there?
Richard Hudgins 12-21-2014 04:24 PM
Brett,
I do not know what pedal assembly you have. Either the Tilton or the Wilwood units fit the pedal box.
Each one uses a different adjuster cable.
If it was my car I would fab up an electric drive for the cable so that it would be easy to adjust between corners. Pretty easy to do and inexpensive as well. Just a simple DC gear motor, a cable, and a switch mounted on the steering or the shifter.
Of course one would probably wish to have programmable position stops but this would be pretty easy as well. A op-amp, a rotary pot, and a logic chip should do the trick.
I am sure that you have some EE buddies that could whip out the circuit for you.
AL427SBF 12-21-2014 05:14 PM
Originally Posted by Richard Hudgins (Post 1330903)
Brett,
Appreciate the input Richard, once I get past the big hurdles I may give that some thought :cool:
vector1 12-22-2014 08:26 AM
Mat got a good deal on some actuators off ebay.
AL427SBF 12-22-2014 08:52 AM
I hope he got the Linak LA12 units -
http://www.linak.com/corporate/pdf/e...0sheet_eng.pdf
The servo control circuit is made to work with it, don't think a broader plug'n play is possible with that circuit (notwithstanding mods).
