-   -   351W oil pan (http://www.clubcobra.com/forums/small-block-talk/40383-351w-oil-pan.html)
super38 04-08-2003 08:29 PM
351W oil pan
Does anyone know of a shorter than standard oil pan with kick outs for a 351W. Also a shorter oil pump pick up. Thanks
Ant 04-08-2003 10:37 PM
351 Oil Pan
Most companies like Miloden, Canton Aviard have road race style oil pans with so called ears on them, they have swinging gates, that swing inwards towards the oil pickup to minimise oil surge - for the 351W.
If you have an oil pump clearance problem you may be getting into serious problems with the need to go smaller in the flywheel and bellhousing, if clearance is a problem.
Another alternative is to mount a belt driven oil pump on the front of the engine and having it mounted lower than the oil level, with a flexible line to the pickup, and the rest is easy plumb it the outlet straight into the main oil gallery!
Else go dry sumped and have heaps of clearance!
Ant
Bart Carter 04-09-2003 12:33 AM
Levy Racing has the exact thing that you need. Custom made, shorter, baffles, etc.
Their number is 480-446-8442
