-   -   351w Aluminum Block (http://www.clubcobra.com/forums/small-block-talk/54752-351w-aluminum-block.html)
bkniep 06-16-2004 08:53 AM
351w Aluminum Block
If I am looking for 400 bhp and good driveability along with minimal weight, are there any disadvantgaes to an aluminum block. Reliability? I am not looking for max power, but rather a reliable and streetable engine in a very light weight pkg.
Bill
blykins 06-16-2004 09:13 AM
The extra cost to me isn't worth the 90-100 lbs.....If you're not racing, you'll never know which block is under the hood.....You're probably gonna pay around $3500 at least for an aluminum block.
Mike Simard 06-16-2004 09:36 AM
The aluminum blocks are better than a stock block aside from the weight. They have 4 bolt mains, blind tapped head bolt holes, taller lifter bores for roller lifters and larger bore capability. If you can afford it, it's a very good thing to have.
Yes, you will feel the 90 lbs missing. The steering will be lighter and your car will turn in better.
750hp 06-16-2004 11:29 PM
... and now that David Kee is producing his alloy toploaders, there's another 40lb weight saving !
