HEI Distributor
http://www.clubcobra.com/forums/small-block-talk/71241-hei-distributor.html)
| tman8 |
07-17-2006 07:37 PM |
HEI Distributor
Iv got a 302 crate from ford when I install my distributer is about 1/16 t0 1/8 from siting on the manifold its all new so whats up? Its a Pertronix flame thrower Dis it does the same thing on my 78 302 block Im stroking.
Thanks
| Jac Mac |
07-17-2006 10:31 PM |
Dont you mean 1/16 to 1/8 from sitting against the shoulder on the block. It sounds like one of two things. Either the gear is fitted in the wrong position or the hex that the oil pump drive fits into has not been machined deep enough. Sometimes the broach that forms the spline will leave a metal shaveing behind that gets past QC. Have you got access to a bare block that you can trial fit the dist alone too & if thats OK then bolt a pump & drive up and check that you have a small amount of free vertical movement of the shaft. You should also be able to lift the dist gear up easily by a small amount (0.010" approx). Of course you could just cross reference all these measurments from your old dist, but I prefer the other method so you can actually see the clearance.
Jac Mac
| jarendall |
07-19-2006 01:21 PM |
there are two different length shafts for the 302 distributor, you may need the shorter shaft distributor, also when I installed my Mallory distributor it would not set all the way down, turned it one tooth and it droped all the way down, the alighment is tight
| All times are GMT -7. The time now is 03:17 PM. |
