Old 10-21-2006, 09:31 AM
Default Serpintine setup water pump required
I have a question regarding serpentine belt setup for a SB ford (1986 302). I would like to run a serpentine belt using only the crank, alternator and water pump. Trying to locate a standard rotation water pump c/w the proper ribbed pulley is very difficult as all the local parts supplier require an original application. Any suggestion or direction would be of help.
Thanks Brad
Old 10-21-2006, 10:07 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I tried to find the same water pump pully, didn't turn up and March was so expensive I lost hope.
So, I run the smooth surface one. It is great. I used to jump belts at RPMs above 7500, now I can turn all the way up to 9000.
Note: I had to machine the water pump pully to fit my 1971 Boss 351 engine. I also had to turn the crank pully, but I am very happy with my current serpentine setup.
Hope this helps.
Old 10-21-2006, 10:24 AM
Rick Parker's Avatar
In OEM application the reverse rotation is utilized because the backside of the belt (SMOOTH) is what drives the pump. The "Big Three" did this primarily to aid in engine packaging. All OEM water pump pulleys are therefore without grooves. You can find grooved pulleys allowing for conventional "Clockwise" rotation but will have to go to aftermarket. March, Coleman, and others. Once the right pulley set up is decided upon the hunt will then change to find the coorrect belt length. The Nextel & Busch teams have done this for years. The parasitic loses are less with this type of belt setup also. Find a circle track racer supply shop they will be able to point you in the right direction.
Old 10-21-2006, 12:34 PM
mikiec's Avatar
This may help... http://www.replicaparts.com/standard...ump%20page.htm
Old 10-21-2006, 01:14 PM
SuperHart's Avatar
Send a message via AIM to SuperHart
Please allow me to post my solution to your problem. I had exactly the same problem and wanted to convert to a flat ribbed belt using only the crank, water pump and alternator pullies. This is a long article taken directly from my build page but I hope it provides you with some useful ideas.
"I had this urge to convert the fan belt from a V-belt arrangement to a serpentine arrangement. There were a couple of mandatory guidelines I wanted to follow. First, I wanted to try and do this on a budget rather than opt for all the high priced aftermarket BLING. Because I am running a early 351W with the original timing cover and standard rotation water pump (5 3/4" from timing cover to pulley flange) that also created a couple of fitment problems. My alternator is in the low passenger side mounting location and must remain there because to raise it up would cause interference with my FE expansion tank. Second, it cannot be adjusted forward more than 1/2" because of potential interference between the alternator fan and the right upper A-frame support on the chassis. Obviously, the alternator MUST remain in the factory stock location in order to work for me. A call to the March Pulley people drew the response that I could use their serpentine conversion kit but would have to space the crank pulley forward 1" to line it up with the water pump pulley. Then the alternator would also require spacing forward 1". The other option was to replace the timing cover and use a SHORT water pump. The March tech cautioned about swapping a short water pump onto an early timing cover, something about incompatibility of the water port holes between the cover and the newer pump resulting in a great likelihood of a leaking problem. The March Option was therefore scrapped."
"First, I removed the V-belt pulleys and took some critical measurements. My damper is 3" in depth. I measured 4 3/16" from the face of the damper to the face of the water pump flange. The V-belt crank pulley (C9OE-6312-E) has a depth of 1 1/2" from the face of the damper to the rear of the belt groove. The V-belt water pump pulley (D1AE-8509-AA) has an inside depth of 2 11/16" for a total of 4 3/16" that matches the damper/water pump distance."
"Now the search was on for the proper serpentine pulleys. I was able to find TWO different diameter stock Ford serpentine crank pulleys with a back spacing of 1 3/8", one measuring 4 3/4" in diameter and the other 6 1/8". Just out of luck I happened to spy a water pump pulley on eBay from a 1988 Thunderbird Turbo Coupe 2.4L that had an inside depth of 2 9/16" and a diameter of 5 7/8". It was ribbed and was a two belt pulley. This pulley has a part number of E7SZ-8509-A which is the double belt model for air cond. The single belt pulley is # E7SZ-8509-B. I'm not sure if they were used on other years or models but the part numbers should help there. Of course, I wanted to remove the front pulley. I found that the front pulley is merely an add-on "cap" secured by four tiny pin welds through the front of the nose. All I had to do was drill out the welds with a 3/16" drill bit and carefully pop off the front pulley. No sweat."
"When installed, the water pump pulley was still forward of the crank pulley and that would require adjustment. Using a straight edge along the front edge of the water pump pulley groove I sighted down to the crank pulley and measured that the crank pulley would need to be spaced forward 1/4" (.250) to achieve a perfect alignment. I then double checked this measurement by measuring the depth of the serpentine pulleys. The crank pulley (E4ZE-6312-A7A) measured 1 3/8" from the damper to the rear of the belt groove while the water pump pulley (E7SZ-8509-A) measured 2 9/16" internal depth for a total of 3 15/16", exactly 1/4" less than needed. Ford Motorsports offers a crank pulley spacer for the early four bolt pulleys that measures .350 thick so I purchased one of them ($28 from the local Ford Motorsports vendor) and turned it down to .250 on the lathe following the factory contour. This spacer has an indexing collar machined into the back and the front to perfectly align the pulleys with the crank damper so I made sure to accurately maintain the ridge on the front of the spacer during the machining process. The adapter is aluminum so it was a cinch to cut. Now the crank and water pump pulleys were perfectly aligned. I bolted the spacer and crank pulley onto the damper using bolts 1/4" longer than stock. The alternator was spaced forward using two 1/8" thick washers. I decided to use the 6 1/8" crank pulley (Ford part # E4ZE-6312-A7A) for a couple of reasons. First, my car is intended as a roadster, not a racer. Using the larger crank pulley will result in a slight overdrive of the water pump which is probably a good thing for the street, might help improve cooling at idle and in traffic. If I had used the smaller pulley the water pump would have been underdriven significantly and that might not have been so good. I finished off the installation with a 41" Dayco belt from my local NAPA store. OH, those guys do LOVE to see me coming. I can hear their moans and groans as they watch me pull up to the door. The entire swap looks great and accomplished all my objectives. Total cost for pulleys, crank spacer and serpentine belt, under $60.00. If I had opted for a complete March Serpentine conversion kit with timing cover and standard rotation short water pump my cost would have exceeded $600.00."
Old 10-22-2006, 03:03 PM
I see that a couple of the solutions are on early 351 engines. Will these standard rotation water pumps also fit the 1986 302. Looking for a year and model to go to supplier with to get a new water pump that will fit the 1986 302 engine.
Brad
Old 10-22-2006, 05:43 PM
All throughout the 70's; the 302's used v belts and standard rotation water pumps. Any of those pumps, perhaps even those for 289 will work for you.
Old 10-22-2006, 08:36 PM
Cobra Make, Engine: BDR 302 AFR 165
Check your timing cover I believe there are differences in a standard vs. reverse timing cover.
Old 10-31-2006, 04:34 PM
To this point I have located a standard rotation pump, but the water inlets in the timing cover are at a different angle. The search continues. May use kit from previous post
Thanks Brad
