November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-02-2007, 08:32 AM
Cobra Make, Engine: ERA FIA; 331 stroker; TKO 600:3.54 Rear
Default Sources for Lightened Steel Flywheel
My car is coming together and I need to get lightened steel flywheel for a 302 (331 stroker). 157 tooth, 28 ounce balance. Any recommendations on high quality flywheel sources? Thanks, Rickd
Old 11-02-2007, 08:41 AM
DAVID GAGNARD's Avatar
If you can't find what you are looking for, take a good steel flywheel to your local machine shop and have them turn it down to your desired weight..........
Back in my dirt track days, the rules changed and we could not use lightweight aluminum flywheels anymore.......we expiremented with "lightened" steel wheels and actually had one down to the aluminum weight and ran it for a year with no problems........
I would not recommend it or put one like that in my own car though......A steel wheel can be lightened up a lot without losing reliability and safety.........
David
DAVID GAGNARD
Old 11-02-2007, 11:33 AM
Cobra Make, Engine: Unique 427SC/331/5 forward
Why go thru all that? - get an aluminum wheel and get the same results with less aggravation. They work just fine, no warping issues, Fidenza's have replaceable friction faces (if you ever need it), etc.
Lightening a steel wheel would present some issues, I would think. Hope you've got a scattershield on the car, for starters. You would have to cut a bunch off the face of the wheel to take much weight off, too, and not certain how that would affect the clutch assembly - less thread contact for pressure plate bolts, strength of ring gear contact, etc.
All are maybes....except for using an aluminum wheel. Works great on a street car.
Old 11-02-2007, 12:33 PM
TB is right. You can poll the folks here and see what they think of their aluminum flywheels (I like mine). Do not get mislead by other forums talking about launch inertia with heavier flywheels -- you don't need that in a light Cobra (with the exception of pure drag machines).
Old 11-02-2007, 01:47 PM
Is Fidanza the way to go on aluminum fly wheels?
Old 11-02-2007, 01:49 PM
CobraEd's Avatar
I have a RAM aluminum flywheel. SFI rated. I love it!
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
