| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
09-25-2008, 08:25 PM
CA
Spark Plug Gap- Poll
I had the idea to open up some basic topics to help the newbies / non-wrench turners to care for their cobras.
In so, getting a sense of SBF spark plug gaps, and what they run in.
-- in my experience;
with a points ignition systems in small block ford, a plug gap of .032 to .035" is fucntional for a stock distributor (points type) and a stock coil.
if you add a magnetic trigger (pertronix) to the distributor and a hotter coil that can allow you to open up the spark plug gap to .035-.038"
If you run a duraspark or HEI you can open the gap to .045-.049 depending on camshaft, carb and timing.
With an MSD or other type of capacitive (multi) spark discharge box, that can avail you to open the gap up .044-.059 depending on many factors.
In my experience, the narrower the plug gap - the smoother the idle can be, but this will take away from power at upper rpms. also there can be to-wide of a gap causing the engine to have a rattly idle and not feel like pulling under load, like a miss' under load.
-- open for other to add their experience!
--Steve
09-25-2008, 08:48 PM
ca
Cobra Make, Engine: spf #1723 427w
MSD... .045 autolite 3924. 351/427w
Greg spf 1723
09-25-2008, 10:42 PM
Ca
MSD Distributor, MSD-6T box(Analog), UR5 NGK plugs @ .045 gap, 289 with 48 IDA's
Rick
09-26-2008, 12:31 AM
No
Cobra Make, Engine: Unfortunataly ; none
Mallory unilite + Mallory 6A, NGK BCP6 @ .045 gap, 347 4 x 48IDF.
RS
08-15-2009, 05:42 AM
No
New gap
.032 " (0,8mm) after reading high A/F (10- 12) and advice from a guy. Saying high compression pressures also should have smaller gap.
Does it work better? Time will tell.
08-15-2009, 06:18 AM
CA
.039/.042 with a Jacobs Pro Racing unit. But since Jacobs is no longer worth anything I will be changing to another type unit one of these days. Also stay away from he Platinum plugs if you do have a Jacobs.I tried them once and it ran crappy as they threw off the resistance readings.
08-15-2009, 06:58 AM
Ma
Hi,
Any high peformance engine with high compression, or power adder I tell to set gap at .035. It's best to get the spark than a misfire. Large plug gaps also burn out ignition wires. You can see wires that are like new but burned near the cap. They have a brown tinge to them.
Large plug gaps are for low performnce emissions engines.
I remember in the late 70's misfires at the rotor shorting to the distributor shaft....
Think of it as a .22 hit is better than a .45 miss...
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
08-15-2009, 12:40 PM
mo
Good info guys
  I agree Life is way to short to worry about gas milage.Other rides Crewcab Super Duty F350 Ford,Shlby Charger,66Mustang/Frankinstang,Chevy Van,KTM Dualsport,FFR Daytona Coupe SOLD... RUN N GUN 06,07,08,09 Hallet 09,
08-20-2009, 11:09 AM
No
I'll install my new Denso- equivalent of NGK BCP7E at .035" this evening.
Maybe same thing will happen as when I changed from 5'ers to 6'ers?
08-20-2009, 12:35 PM
Cobra Make, Engine: ERA #698 428 Toploader
M.S.D. with E3 plugs, 3 tips, no gapping, no problem.
08-20-2009, 02:32 PM
Club Cobra Member
NJ
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Mallory 6AL Autolite 3924 .040 gap
 Snakebit
08-20-2009, 06:40 PM
OK
Cobra Make, Engine: Fords
Stock 289 Hi-Po , 10:1 compression w/ MSD Digital 6, Autolite 45's gapped @ .45
same as above with vintage Paxton (6 lbs. psi maximum), Autolite 45's gapped @ .28
Z. Ray
'65 K code Mustang
'66 Galaxie 500
08-20-2009, 09:15 PM
ca
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
FE, Champion RC12YC, .032, 10:1, MSD.
Dave
