-   -   Oil Pan/Scatter Shield (http://www.clubcobra.com/forums/small-block-talk/94762-oil-pan-scatter-shield.html)
autobody prof. 02-12-2009 09:29 PM
Need some info on what oil pan and scatter shield to use on a 427 stroker(351w based).
sllib 02-13-2009 05:54 AM
I can tell you what I did and why. My block is bigger in some areas because it has 4-bolt mains. Canton and a few others make oil pans to fit this block but I went with a marine-style pan from Armandos that was about $100 lower priced and is lower in profile for the same capacity as the sump-type pans. If you're using a factory 351W block any good performance pan will work.
I went with the McLeod scatter shield because it supposedly doesn't need to be aligned, but time will tell. The Quick Time shield seems to be very popular lately but it wasn't available when I was buying parts. I hope this helps. At any rate, good luck with your build.
Bill Stradtner
Mac VABCH 02-13-2009 06:49 AM
sllib,
Does Armondos have a wb page? Also I am in VA Bch and have a Dart block, I would like to come by an check out your oil pan and car. PM me if this is ok with you.
autobody prof.,
I went with a Quick Time B/H and a Canton pan, the pan does sit very low....Mike
xracerbob 02-13-2009 08:49 AM
Armondo's-
http://www.geocities.com/motorcity/flats/1624/
autobody prof. 02-13-2009 06:10 PM
Thanks for the info guy's. I will look into both. Does the Quick Time have to be aligned?
Don
