Old 04-07-2009, 04:01 PM
Caprimaniac's Avatar
Default Advice for a quiet electric carb fuel pump
As spring comes in and the snow melts, the 347 awakens. The engine was started yesterday, and everything looks good.
As a refinement for this season I thought I'd make the fuel pump a bit more quiet by installing a piece of hose between the pump and the aluminium line that runs the lenght inside the car. Although it sounded promising when the pump was run dry, the enourmous whining and grinding came back as soon as fuel was poured into the tenk once more....
The pump is a Summit 130 gph "racing" unit.
And to be honest, it makes alot of noice. - OK; no sound of it as soon as the throttle is "halfway there and beyond"- but a pain in the ass when in traffic. (Anyone else has the same experience?)
Any reasonably priced less noisy pumps you'd like to suggest?
( The engine sports 4 x IDF's and I use an Aeromotive adjustable regulator with a 1/2" return line, 3/8" supply.)
Happy Springtime
RuneS
Old 04-07-2009, 04:21 PM
tboneheller's Avatar
When you say the fuel line "runs the length inside the car", is the line IN the car or UNDER the car?
Old 04-07-2009, 06:31 PM
DocDirk's Avatar
Cobra Make, Engine: West Coast-Ford Performance Solutions 533 BB
Default MIne's a Holley
I bought it from Summit or JEG's, can't remember. Holley puts out 150GPH max I believe... installed it between the trunk and the seat area, on the frame above the axle. Ran fuel line into a conduit I installed to run above the floorpan to the engine compartment. I never hear it probably because of its location.
Dirk
The government giveth and the government taketh away..... if our rights are not God given then they're subject to revision!
Old 04-07-2009, 06:36 PM
Make sure you have rubber isolators on the pump mount or it'll vibrate through the frame.
Either that or take the packing out of your mufflers...
Old 04-07-2009, 06:57 PM
Cashburn's Avatar
Backdraft Racing Dealer
Carter pumps are great for the low noise factor. You only hear the vacuum pump from time to time on this one:
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 04-07-2009, 08:32 PM
Zoom This's Avatar
Maniac....as Cashburn said, the Carter HP pump, model P4600HP is pretty quiet compared to the Holley Blue pump it replaced in my car. I've had mine in my SPF 418W for five years now and no problems. Edelbrock has a quiet electric pump they tout as being extremely quiet.
Old 04-07-2009, 09:07 PM
Cobra Make, Engine: SPF 1474: 482 CI stroked tunnel port 427 with dual quads.
Stay away from the Holley blue pump...not only are they noisy, but very prone to premature failure. Go with a carter pump.
"Some things just get meaner as they get older"
.....Gumball Rally :-)
Old 04-07-2009, 09:48 PM
GlynMeek's Avatar
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Runes...go check out this thread...may be some help!
New Style Electric Fuel Pump Installed - Quiet
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
Old 04-08-2009, 09:10 PM
PANAVIA's Avatar
Another Carter supporter here; quiet , run , cheap. --Steve
Old 04-09-2009, 07:44 AM
Clois Harlan's Avatar
Facet makes a very good and quiet fuel pump. I have Dean Lampe's here at my house but it is a low pressure fuel pump for Webers. Not very noisy at all. In my Cobra I have an Aeroquip that is mounted in the trunk of my car in line with my Fram Fuel Filter. I used a 1/4" rubber cushion between the pump and the frame and I barely hear it.
Clois Harlan
"Let's roll"
"Be part of Something Good
Old 04-15-2009, 11:10 AM
I'll look into holley & carter... the lines run inside the car. (no room underneath the car.)
runes
Old 04-15-2009, 11:50 AM
Jim Doak's Avatar
Cobra Make, Engine: FFR with a 345-horse 302 Crate Engine
Follow-up question: Will running a return line from the fuel pressure regulator back to the gas tank help to quiet-down the pump?
Jim Doak
FFR 2117
Old 04-15-2009, 12:09 PM
onefastmustang's Avatar
I'd vote for the carter as well.. I only hear it when the motors off and I am giving it a second to pressurize the lines to my webers. Once the motor is on you can't hear it at all.. Even at idle.
Old 04-28-2009, 05:54 AM
Jim, yes it will....when you dead-head a pump, it makes them a little noisier. Using a bypass should quiet it down a little.
Old 04-28-2009, 09:33 AM
fkemmerer's Avatar
Cobra Make, Engine: ERA, FE BBF
Happy Springtime
RuneS
Two solutions for you:
1) Checkout the Weldon 600-A. This is a very reliable and quiet pump. I've been using one on my Street Vette (blown and injected for several years now)
2) You can use an Aeromotive Inline Pump (Summit AEI-11101) and a fuel pump controller. The controller will slow down/quiet down the pump below 2500 RPM which also extends its life
Both of these pumps will require a regulator and a return line and both should be good for 600+hp.
-Fred
Last edited by fkemmerer; 04-28-2009 at 09:36 AM.. Reason: Forgot an important detail
Old 08-11-2009, 04:15 PM
Hello.
Lot's of options here.. Change of pump is near, but I hope to do one more check before I give this one up.
This setup does have a return- line/ bypass. The pump then runs on full steam at all times. (1/2" return line, 3/8" feed line from/ to regulator).
I did have some particles trapped in my fuel- filter (75? microns) when i opened it, and some of the pump- noice might be caused by trapped debris? I'll open up and inspect when I change my tank..... Have welded one with a catch- tank at the rear/ bottom to be sure the pump get what it need even when tank is 1/4 full.
Thanks.
Old 08-11-2009, 06:19 PM
bobcowan's Avatar
Consider an in tank pump. I don't know what fuel tank you do have, but if that's an option it would solve a lot of your issues.
Old 08-11-2009, 06:29 PM
If you dont have fuel injection get rid of the stupid non needed noisy prime loosing electric fuel pump and install a mechanical one. the only hitch is you will need an ecentric for the camshaft and possibly a large dowel pin in the camshaft to drive the ecentric.
Old 08-20-2009, 11:06 AM
Mechanic isn't stupid at all. An option to consider.
Is the mech pump OK when you rev the engine to say 8000 rpm?
You'll still need the pressure regulator?
Hmm... Not sure if there's room for one, though.
RS
Old 08-20-2009, 02:05 PM
priobe's Avatar
Clois,
What model Aeromotive do you have, I have an Aeromotive pump 11213 (I believe)
Mine is noisey when idling but I have not insolated the pump.
But it is a great pump.
