SPF ceramic coating vs Jet Hot
How does the SPF ceramic exhaust coatings hold up (black and silver)? Heat induced apprearance changes? Any recommendations on black vs silver (except initial color preferrence)? Also, I assume the SPF ceramic coatinga are the same as Jet Hot coatings. Correct? Maybe can save some $s here.
Both are ceramic coatings. As with some many things the product is only as good as the person doing the work. If done correctly will hold up for years and years, if not then you will probably see some light surface rust.
But look that black SPF (SPO between 2100 and 2300):
http://cid-801515003f0acfe4.skydrive...blc%5E_cob.png Has a Rush 427SR engine. It it possible to bing the color back to black? Thanks Juergen |
Swain Technology's version of ceramic coating, texture of semi-rough sandpaper ( ceramic particles ) in white only. Can be sprayed black with high temp paint. Process is not licensed to franchises, they are located in upstate NY. Had two different sets of headers and side pipes coated by Swain, excellent results.
http://www.swaintech.com/store.asp?pid=10969 |
btw. it has around 2000 miles on the gauge. Any idea, what causes the sidepipes so burned?
Thx, Juergen |
| All times are GMT -7. The time now is 01:54 PM. |
