-   Superformance (http://www.clubcobra.com/forums/superformance/)
-   -   SPF Submarine belt attachment sites (http://www.clubcobra.com/forums/superformance/107476-spf-submarine-belt-attachment-sites.html)
pfact 11-01-2010 02:47 PM
Is there an easy way to install a submarine belt in a SPF?
Phil
Blas 11-01-2010 05:39 PM
You have a message...
STCinc 11-01-2010 06:51 PM
I went with 6 point set-up and used the front mounting bolts to secure.
http://www.summitracing.com/parts/BOB-50505/
ACademic 11-01-2010 09:34 PM
There should be a supporting member or piece of steel that the seats bolt to. That is the part that you want to drill into and mount your anti-submarine strap. Probably a steel strap welded to the main frame. Measure three times and drill once.
