Like Tree1Likes
  • 1 Post By tortuga
Old 07-05-2015, 10:55 PM
Default Sorry New Owner, lots of Posts: Broken Radiator drain bolt
My car came with a sheared off brass (?) Rad drain bolt on the drivers side, first time i drained it by removing the lower hose (partially)...This time I want to do everything right so I don't have to do it again, including removing the drain bolt and replacing it maybe with a valve or plastic?d Brass and aluminum in contact with hot water seems like a bad idea...
Anyone easyout one of these? Worried that the I/O will just grow the brass jamming it harder...
Superformance 1764
Built 427W
Aiken SC USA
Old 07-06-2015, 12:06 AM
DWRAT's Avatar
Drill the brass plug and remove it with a easy out.
I wouldn't put a valve there as it is pretty low and could get hit and shear off.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 07-06-2015, 03:49 AM
Ron61's Avatar
If the radiator isn't to hard to remove, maybe you would be ahead to take it to a radiator shop where they have the equipment to do this and also ask them about your concerns with the Brass and Aluminum in contact with hot water. I believe my drain plug is steel.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 07-06-2015, 09:09 AM
Default Rad removal?
I was sort of thinking the same thing, i would rather not give them the whole car for obvious reasons...
What is involved in removing the rad? It is really tucked in there from what i can see, maybe remove by going straight down?
Morris likes this.
Superformance 1764
Built 427W
Aiken SC USA
Old 07-06-2015, 08:54 PM
Left handed drill backed it right out...Its an M10x1.5 for reference, got a new flanged bolt and copper washer, locktite blued it and good to go...
Superformance 1764
Built 427W
Aiken SC USA
Old 07-07-2015, 05:38 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Why did you Locktite it? Copper washer will seal it and keep it snug. No different than your oil pan bolt.
SPFWiringDiagrams@Comcast.net
Old 07-07-2015, 02:38 PM
Unlike the oil pan bolt this will stay in for years...Even though after doing it It dawned on me that i will just be removing it again to (re) do my intake install (slow and VERY methodically this time).
Real reason? I have a bunch of loctite...LOL
Superformance 1764
Built 427W
Aiken SC USA
